4 members (Hotrod Lincoln, KCMongo, Peggy M, eclector), 166 guests, and 2 robots.
Topics128,034
Posts1,055,533
Members48,425
#171373 10/29/2004 2:20 PM
Are the Chevy truck hoods from 47-55 1st all the same?
Thanks Mac
#171374 10/29/2004 3:29 PM
Sorta...The emblem mounting points (I believe) are different. Might be some differences on the internal bracing, as well. :confused: Hope this helps.
Regards,
Wannabe smile
"Don't expect anything and you'll never be disappointed"
#171375 10/29/2004 3:34 PM
Thats what i thought. The emblems really aren't a problem i can fill and put new holes in if need be.
#171376 10/29/2004 3:43 PM
Anonymous
Unregistered
Anonymous
Unregistered
In terms of fit and function the hoods are the same for all 1/2, 3/4 and 1 ton trucks. The 1.5 ton and upward have a different shape at the back corners.
#171377 10/29/2004 4:55 PM
Houston'
Thanks that i was pretty sure on also.
Thanks Mac
#171378 10/29/2004 5:30 PM
Aren't the 1.5 and up hoods also longer and bigger curves through the fender area? :confused:
Regards,
Wannabe smile
#171379 10/29/2004 6:52 PM
guys, yes the 1 1/2 ton and up hoods are longer by approx 3 1/2 inches.but in a pinch you can use the inner rear stiffener/brace on either hood as its the same width. same goes for the front. wink
#171380 10/29/2004 7:01 PM
also,not to take over a post, but save that old hood. as martin sr would say its the same gauge metal as the rest of the truck. so u can use it as patch panel pcs ...easier to weld together wink
