3 members (Hotrod Lincoln, Bill Hanlon, 1 invisible), 162 guests, and 3 robots.
Topics128,088
Posts1,056,113
Members48,434
#171221 01/24/2005 3:12 PM
For my birthday my wife gave me 2 12 volt windshield wiper motors from Speedway motors. Stainless arms, self parking etc. They will not be syncronized to each other because they're 2 seperate motors but I dont care about that.
I hope to install them in the spring.
Has anyone else done this?
Gravity - It's not just a good idea, it's the law.
#171222 01/24/2005 5:17 PM
Only folks that want to: 1. Drive in the rain......& 2. WANT TO SEE
#171223 01/24/2005 5:20 PM
I put 2 6V electrics in my 46 GMC, and thought it was a gas that I could run them individually
w/ a passenger, don't put that one on and watch the "back seat drivin" start! grin
they work fine, tho sometimes I had a problem w/ the arms being able to hold the blades tight to the glass at higher speeds w/ a gusty headwind eek
#171224 01/24/2005 5:23 PM
Bill, I'm not sure what you motors look like but here's what I did with my 46. I got a motor and wiper arm from JC Whitney. The motor is just small enough to fit in the hole where the original one was. I had to make a blank cover plate for it. It needs to be flat ie. no indents for the switch like the orig. cover plate. I think you can buy this block-out plate from some of the vendors. Then I drilled a hole in the plate for a push-pull switch, turned the switch on the motor in the on position and wired in the switch.
The only other thing I did was to take about 1/4" off the length of the shaft to make the wiper fit the windshield better. The whole thing was a pretty easy install.
Good Luck
George
#171225 01/24/2005 6:09 PM
I need to do the same for my 49 suburban. What is the best option to get them where they are in sync. Does anyone know of a vendor that does a direct replacement 12V motor?
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
#171226 01/24/2005 6:33 PM
Can't you use one switch with two motors? If it's cheap enough for the aftermarket single unit deals and they fit it sounds better than the 180.00 retrofit deals. Depending on what the jc whitney or speedway ones cost.
53 3100
1929 Ford Roadster Pickup
1934 Ford Pickup
68 Plymouth Satellite RR Clone 2 Door
My Fleet
#171227 01/24/2005 9:03 PM
Quote
Newport Engineering makes a direct replacement for the vacuum wiper motor in your '49. I mounts in the same place and uses the same arms to move the vipers. I used mine this morning on the way to work...
Your favorite vender probably carries it.
#171228 01/24/2005 10:08 PM
If you're running a 12v system, I think a '55-'57 truck electric wiper motor is a direct replacement for the AD vaccum units. It was an option, and I think the vacuum motors were identical between the AD and early TF trucks, so I don't see any problems. If I can find an affordable one, I'll give it a shot.
1954 GMC De Luxe COE
#171229 01/25/2005 4:23 AM
That electric unit from Newport works well. I got mine from, I believe, Chevy Duty. It goes right in, although working under the dash can be a challenge. Also, the switch will not work in the old hole--and they tell you that in the directions. I just moved over a couple inches and drilled a new hole, although you could put it anywhere you want.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
#171230 01/25/2005 5:02 AM
The Speedway motors wiper motors are about $30-$40 each, including the arm and blade.
#171231 01/27/2005 4:53 AM
Junior Member
Junior Member
Is Speedway motors on the web? If not, could someone post an address. I'm tired of these vacuum wipers.
'50, '59, 1/2T, GMC
#171232 01/27/2005 5:32 AM
www.speedwaymotors.com then go to streetrod products. All the way to the bottom of the page - windshield products.
#91123501
Good luck I hope they're good.
