| | | Forums66 Topics128,034 Posts1,055,544 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2000 Posts: 175 Shop Shark | | Shop Shark Joined: Jan 2000 Posts: 175 | For my birthday my wife gave me 2 12 volt windshield wiper motors from Speedway motors. Stainless arms, self parking etc. They will not be syncronized to each other because they're 2 seperate motors but I dont care about that. I hope to install them in the spring. Has anyone else done this?
Gravity - It's not just a good idea, it's the law.
| | | | | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | Only folks that want to: 1. Drive in the rain......& 2. WANT TO SEE | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I put 2 6V electrics in my 46 GMC, and thought it was a gas that I could run them individually w/ a passenger, don't put that one on and watch the "back seat drivin" start! they work fine, tho sometimes I had a problem w/ the arms being able to hold the blades tight to the glass at higher speeds w/ a gusty headwind Bill | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Bill, I'm not sure what you motors look like but here's what I did with my 46. I got a motor and wiper arm from JC Whitney. The motor is just small enough to fit in the hole where the original one was. I had to make a blank cover plate for it. It needs to be flat ie. no indents for the switch like the orig. cover plate. I think you can buy this block-out plate from some of the vendors. Then I drilled a hole in the plate for a push-pull switch, turned the switch on the motor in the on position and wired in the switch. The only other thing I did was to take about 1/4" off the length of the shaft to make the wiper fit the windshield better. The whole thing was a pretty easy install. Good Luck George | | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | I need to do the same for my 49 suburban. What is the best option to get them where they are in sync. Does anyone know of a vendor that does a direct replacement 12V motor?
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
| | | | | Joined: Apr 2001 Posts: 162 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 162 | Can't you use one switch with two motors? If it's cheap enough for the aftermarket single unit deals and they fit it sounds better than the 180.00 retrofit deals. Depending on what the jc whitney or speedway ones cost.
53 3100 1929 Ford Roadster Pickup 1934 Ford Pickup 68 Plymouth Satellite RR Clone 2 Door My Fleet
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Originally posted by 49bourbon: I need to do the same for my 49 suburban. What is the best option to get them where they are in sync. Does anyone know of a vendor that does a direct replacement 12V motor? Newport Engineering makes a direct replacement for the vacuum wiper motor in your '49. I mounts in the same place and uses the same arms to move the vipers. I used mine this morning on the way to work... Your favorite vender probably carries it.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | If you're running a 12v system, I think a '55-'57 truck electric wiper motor is a direct replacement for the AD vaccum units. It was an option, and I think the vacuum motors were identical between the AD and early TF trucks, so I don't see any problems. If I can find an affordable one, I'll give it a shot. | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | That electric unit from Newport works well. I got mine from, I believe, Chevy Duty. It goes right in, although working under the dash can be a challenge. Also, the switch will not work in the old hole--and they tell you that in the directions. I just moved over a couple inches and drilled a new hole, although you could put it anywhere you want. | | | | | Joined: Jan 2000 Posts: 175 Shop Shark | | Shop Shark Joined: Jan 2000 Posts: 175 | The Speedway motors wiper motors are about $30-$40 each, including the arm and blade.
| | | | | Joined: May 2003 Posts: 22 Junior Member | | Junior Member Joined: May 2003 Posts: 22 | Is Speedway motors on the web? If not, could someone post an address. I'm tired of these vacuum wipers.
'50, '59, 1/2T, GMC
| | | | | Joined: Jan 2000 Posts: 175 Shop Shark | | Shop Shark Joined: Jan 2000 Posts: 175 | www.speedwaymotors.com then go to streetrod products. All the way to the bottom of the page - windshield products. #91123501 Good luck I hope they're good.
