7 members (fonz8261, Rexville48, 1955 1 Series, Peggy M, mk72, Shardean, 55shaker), 60 guests, and 2 robots.
Topics128,022
Posts1,055,387
Members48,422
#170501 01/16/2005 4:42 PM
I have a 1955 2nd series truck with no number on the door jamb plate. Just the word CHEVOLET is visible. The left frame rail is stamped in two places with the vin number. Is this the way it was done?
#170502 01/16/2005 4:55 PM
If you have the original engine, check the serial number on it. It's the only other possibility.
Fred
52 3600
69 C-10
#170503 01/16/2005 6:15 PM
if the left frame rail between cab and rad mount has a number stamped, that's the VIN - if ya clean that door post plate carefully it should show there the same cuz it was stamped in, not painted on - tho' you might be seein just the GVW plate, w/ the smaller plate that has the VIN gone
#170504 01/18/2005 3:17 AM
Junior Member
Junior Member
hi there try looking under the seat some times they put a build sheet under there & maybe under the dash see ya
#170505 01/18/2005 3:28 AM
Junior Member
Junior Member
and look for my name in big bolts there was a email link there to take you to a web address that will help you fine out what all the numbers mean see ya
