| | | Forums66 Topics128,165 Posts1,056,987 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#17025 08/16/2003 6:40 PM | Joined: Jul 2003 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2003 Posts: 33 | I'm finally back after 2-3 hours fixing the mayhem caused by the msblast worm. Someone needs to find the guy and use his head for a mop and his butt for a broom!
I did a compression check on my 49 3600, it has a 55 235 6cyl engine. The cylinder farthest back, I don't what the number of the cylinder would be had 0 compression. The other five ranged between 125-127psi. The engine runs rough but does not smoke. Any advice on what the problem may be?
Thanks!! | | |
#17026 08/16/2003 7:22 PM | Joined: Jan 1970 Posts: 365 Shop Shark | | Shop Shark Joined: Jan 1970 Posts: 365 | Valve problem. Turn the engine over until it is in #6 TDC. The rotor will point to the #6 plug wire terminal on the distributor cap. Both valves will be closed. Shoot some air into the cyliinder and listen to the intake and the exhaust to see where the air is escaping--that is the valve not seating. | | |
#17027 08/17/2003 7:25 PM | Joined: Jul 2003 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2003 Posts: 33 | Racecarl,
Thanks for the input. I'll try what you suggest. However, I may just pull the head and have it fixed. Are rebuilt heads available?
Dierks | | |
#17028 08/18/2003 10:37 PM | Joined: Jul 2003 Posts: 132 'Bolter | | 'Bolter Joined: Jul 2003 Posts: 132 | My suggestion is to first run a compression check as you did, then add a tablespoon or so of oil to each cylinder and recheck. If there is a significant difference in the wet/dry readings the problem will be rings or pistons. If no change it is likely valve related. Then check valve clearances, rocker arm condition and cam lift. You still might need to pull the head, but at least you will know why! | | |
#17029 08/19/2003 3:43 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | It would be best not to pull the head until you know what's wrong, if possible. Diagnosis can be tough with the head off.
Fred 52 3600 69 C-10
#17030 08/19/2003 6:02 PM | Joined: Jul 2003 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2003 Posts: 33 | | | |
