1 members (NJC), 78 guests, and 0 robots.
Topics128,035
Posts1,055,564
#170239 10/23/2004 4:13 PM
i thought i would finally put an end to my door rattle on the '57 and install new door latches; i should off left well e'nuff alone and not tried to tweak it one last time. so now not only does the door no longer rattle but no longer opens! both button and inside handle won't budge. entrance/exit through the passenger side is getting old quick. i've tried accessing in doors' guts through the panel but the bend in it allows no access to the screws with the door in the closed postion!?
#170240 10/23/2004 8:49 PM
With the door push button depressed, shove the door closed harder, it may unlatch.
The other thing is to have someone inside shoving, NOT kicking,while you are pulling outward (WATCHOUT the door does not open and hit you!! eek )
#170241 10/23/2004 8:51 PM
I installed new latches on my 55,same thing as your 57.I am still tweeking mine to get the doors to close easy.Only thing I can think of trying on yours would be to try using a mallet on the outside push button,preferably a rubber mallet.
#170242 10/24/2004 12:49 AM
Can't offer any help . But I'm glad I'm not the only one who improves things to the point of disaster
#170243 10/26/2004 1:42 AM
thanx gang, i guess i'll give the two person method a shot first. funny how the mind works; after driving the '57 with the "passenger exit" and almost getting used to it, i found myself almost using that exit on other vehicles as well! db
#170244 10/26/2004 5:50 AM
eek
Eek - too much tweek!
The story of my life.
I'm constantly trying to make the 37 run, ride and be as quite as a 97!!
I end up in trouble 10 times out of 10!!
