1 members (Hotrod Lincoln), 327 guests, and 3 robots.
Topics128,169
Posts1,057,102
Members48,463
#170153 02/06/2005 2:48 PM
In the other thread about under the bed gas tanks, some of yall used a tank from a F##d, I installed a tank that the guy said was from a T bird. What am I going to get into with the sending unit???? I have not tried to ohm the thing yet
#170154 02/07/2005 5:31 AM
Should work fine. Most senders back then read from 0-90 ohms. Check yers and it should match.
BTW....... the beer keg float GM uses are available seperately from Ford for about $4.00 each! Same exact part. (Gm doesn't sell it seperately)
John Kennedy
1950 Suburban street rod
Pics in the Gallery.......
new site up!
http://home.joimail.com/~kennedyjp/
#170155 02/07/2005 2:05 PM
Thanks for the reply Johnny
#170156 02/07/2005 9:52 PM
some f**d senders read 70-10 ohms with 70 being empty and 10 full. This is a problem if you have a GM gage because it is backards. I used a F**d mustang tank and modified the sender by inverting it. I also added some resistors in parallel with the sending wire to compensate for higher resistance. Seems to work but isn't very accurate below 1/4 tank due to the nature of the changes.
'53 chevy 3/4 ton
