8 members (SammyC60, TUTS 59, 52Carl, Mike Roache, TooMany2count, Hawkman, Otto Skorzeny, 1 invisible),
101
Mod | | | Forums66 Topics128,101 Posts1,056,518 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 52 | In the other thread about under the bed gas tanks, some of yall used a tank from a F##d, I installed a tank that the guy said was from a T bird. What am I going to get into with the sending unit???? I have not tried to ohm the thing yet | | | | | Joined: Sep 2001 Posts: 109 Member | | Member Joined: Sep 2001 Posts: 109 | Should work fine. Most senders back then read from 0-90 ohms. Check yers and it should match. BTW....... the beer keg float GM uses are available seperately from Ford for about $4.00 each! Same exact part. (Gm doesn't sell it seperately)
John Kennedy 1950 Suburban street rod Pics in the Gallery....... new site up! http://home.joimail.com/~kennedyjp/
| | | | | Joined: Nov 2007 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 52 | Thanks for the reply Johnny | | | | | Joined: Feb 2002 Posts: 75 Member | | Member Joined: Feb 2002 Posts: 75 | some f**d senders read 70-10 ohms with 70 being empty and 10 full. This is a problem if you have a GM gage because it is backards. I used a F**d mustang tank and modified the sender by inverting it. I also added some resistors in parallel with the sending wire to compensate for higher resistance. Seems to work but isn't very accurate below 1/4 tank due to the nature of the changes.
'53 chevy 3/4 ton
