| | | Forums66 Topics128,082 Posts1,055,961 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2003 Posts: 179 Member | | Member Joined: Jul 2003 Posts: 179 | Hey all...
Picked up the steel to build my rear shock mounts and had a couple of questions.
How much inward angle is optimal when mounting the shock? Newer trucks have the top of the shock angled toward the center of the vehicle. What are the benefits of this? More importantly what are the consequences of reducing this angle by half (to 10deg or so) or removing it altogether (vertical)? - Ryan
59 Apache Step 78 El Camino http://www.wsu.edu/~rsain
| | | | | Joined: Jul 2003 Posts: 179 Member | | Member Joined: Jul 2003 Posts: 179 | I wonder if I could flip sides on my mounting plates (whatever you call them) - to get the shock mount on the outside of the frame? - then do as the commercial and the article you posted suggests - shocks outside the frame.
Alright - ideas folks!!! pics of the frame are at
http://www.wsu.edu/~rsain/apache.html
ps. pics of the rear suspension are not very informative....
- Ryan
| | | | | Joined: Jul 2003 Posts: 179 Member | | Member Joined: Jul 2003 Posts: 179 | Bump....
No one has any comments???
What would you do?
- Ryan
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | ask the Genie  Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
