0 members (), 83 guests, and 3 robots.
Topics128,194
Posts1,057,261
Members48,466
#169578 05/27/2005 3:04 AM
Junior Member
Junior Member
Hello, I am wondering if they make patch panel that you can buy for the cowl vents on the 47-53 trucks. I want to patch and smooth every exterior vent on the truck. I think it would be easier to to buy some if they make them. I want them gone because it will be one less place for rust when it is finished and I am putting air in the truck. Thanks for any help.
Rodney
49' custom 1-ton dually 5 window deluxe
#169579 05/27/2005 4:22 AM
rodney... from my very limited knowledge here on THE BOLT and im sure others will pile on! there are no patch panels so to speak to coverup or otherwise eliminate the cowl vents. the only thing you can do is make your own.you can however use a 51/55 1st series left side cowl repair panel to eliminate the drivers side cowl vent found on 47/50 ad trucks. regards steve sr.
#169580 05/27/2005 12:39 PM
Look on E-bay there are a few companys that make the full cowl panels without the louvers.
47.5 Loadmaster 5 window
48 Chevy 3600
69 GTO convertible
#169581 05/27/2005 1:14 PM
Anonymous
Unregistered
Anonymous
Unregistered
Brothers had them once.
