| | | Forums66 Topics128,059 Posts1,055,820 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2003 Posts: 108 'Bolter | | 'Bolter Joined: Jul 2003 Posts: 108 | I don't doubt this question hasn't come up about a half dozen times, BUT my wife don't let me come in here very often and I missed any previous discussion. SO - My 1.5 ton does NOT have a Polarity Reverse Switch (PRS)on the starter. It is a 6 volt. But when I turn it over, it grinds VERY slowly, even with a new battery on full charge. I have 3 ground straps, 1- Cab to frame, 2- Starter to frame, and 3- Neg battery to frame. MY QUESTION IS: Will adding the PRS make it turn over faster?? Timmer | | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | I don't think so.I think it will cook your starter.check the starter brushes,see how many amps the starter is pulling,may have a bad spot in the field.you can try a 8volt battery
dan-pa
| | | | | Joined: Aug 2002 Posts: 221 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Aug 2002 Posts: 221 | Timmer!
If you are not using good heavy duty 6 volt cables, and those on there are 12 volts---change them all.
If the starter is in good shape it'll turn like a turbine with the right size cable on there.
George | | | | | Joined: Jul 2003 Posts: 108 'Bolter | | 'Bolter Joined: Jul 2003 Posts: 108 | Sounds good, BUT I had the starter rebuilt, but have not checked the field, AND I purchased the cables NEW from Jim Carters for the 6 volt. I just thought I was missing something with the PRS since it was not on the starter, (never was). | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The PRS was used to switch the polarity going through the points and coil. It did not affect the starter current. | | |
