7 members (DavidBraley, Otto Skorzeny, J Lucas, 66flea, Rosco, 55shaker, 1 invisible),
122
Mod | | | Forums66 Topics128,283 Posts1,058,504 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2004 Posts: 288 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 288 | I have been given a 1977 z-28 rear end with 3:42 gears from a camaro f-body.
Will this work as a rear swap on my 55.1? If I understand the conversion chart right it can work.
Thanks, Chris
Chris 1955FirstSeries
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | wont work,,, send it to me,,,  Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Jan 2004 Posts: 288 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 288 | Nice try. The only conflict I can see is the 5 lugs on the rear and 6 lugs on the front.
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | why would that conflict,,drive it like that,,heck, I have seen em with lug nuts missing,,,serious,,good luck with your project,no one ever gives me anything except a hard time,,,why is that,,,Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Jan 2004 Posts: 288 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 288 | Yeah I think I am going to go that route. I eventually would like to put a front clip in the truck so at some point it will switch over to all 5 lug.
Thanks Joker and have a great weekend.
-Chris
| | | | | Joined: Aug 2004 Posts: 476 Moderator | | Moderator Joined: Aug 2004 Posts: 476 | That should be an easy one to find a front clip to match lug bolt patterns. Lots of Camaro/Nova/Monte Carlo front clips find their way into AD trucks.
Don't lose your head to save a minute, You need your head, your brains are in it. Burma-Shave (1947)
| | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Chris,
How bout one of those disc conversion kits....you get discs on the front of your truck, keep the stock front end and get 5 bolt too? I think there is a GM 5 bolt kit. | | | | | Joined: Jun 2004 Posts: 336 Member | | Member Joined: Jun 2004 Posts: 336 | I am using a 77 Camaro Z-28 limited slip rear end in our truck. Front brakes have been converted to use Camaro disks. Here's a pix of the rear end: web page
Gord 1954 1/2 ton 235 4 speed
| | | | | Joined: Jan 2004 Posts: 288 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 288 | Fran and Gord,
With that rear end did you have to modify the drive shaft at all?
I currently am running a 283 from a 68 camaro with the 4 speed saginaw transmission from the same car.
Thanks, Chris
| | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 |
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Oct 2002 Posts: 52 'Bolter | | 'Bolter Joined: Oct 2002 Posts: 52 | Fran/Gord - looks like your springs are also from the Camaro? What did you do for the front spring perches? Got any close ups of those?
I used an '79? (can't remember) Firebird with 3.42 posi - worked great, make sure you get the right offset on the rims or they will rub on the inside against the box. I had the wrong backset on the first set of rims and they would let out a little puff of smoke on hard cornering.
There are a lot of disk brake kits for your a stock front axle that will give you the same lug pattern as the camaro rear.
Life's short - don't waste it.
| | | | | Joined: Jun 2004 Posts: 336 Member | | Member Joined: Jun 2004 Posts: 336 | MG: Those are S10 springs. This truck will be Fran's and she won't be hauling anything too heavy. The front spring perches were made from 3.5 inch square steel tubing. They are kinda ugly, but I don't think they will break! (Nobody will see them once the box and running boards are on).
Chris: the driveshaft was a bit of a challenge. Originally the truck was torque tube. The transmission I have is a SM420, which is a short tranny so a long one piece or a two piece driveshaft was needed. Long 1 piece shafts with a slip yoke are hard to find! I ended up installing a steady bearing with a two piece shaft from a 70's 4x4.
| | | | | Joined: Jan 2004 Posts: 288 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 288 | Tony,
I took the numbers of the engine block and did a search on the net and it came up a 68 Camaro. I don't think I am wrong.
Also discovered the rear end is a posi.
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | Chris, don't believe everything you read on the net. A lot of morons with keyboards out there. I thought '67 was the last year for the 283. It was replaced in '68 with the 307. | | | | | Joined: Jan 2004 Posts: 288 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 288 | My guess would be that the motor is from a 67. Or is there site or process to identify the motor?
Thanks, Chris
| | | | | Joined: Jan 2004 Posts: 223 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 223 | As to the 5 to 6 lug problem, I grew up hearing that '53 car front drums will fit right on the truck spindles. Never tried it, so don't know if it is true. If so, it would be a cheap and easy way to avoid hauling two spares. Steve O | | | | | Joined: Jan 2004 Posts: 288 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 288 | Well tomorrow I am picking up the rear end. I can't wait. I am also going to go the route of a front disc conversion. I am going to sell my 1951 Allis Chalmes WD tractor to help fund the project, hate to do it but $ doesn't grow on trees where I come from. Once the rear end in and the disc conversion is done I think Cragar SS rims are in order. Of course that is a perfect world.
-Chris
| | | | | Joined: Dec 2002 Posts: 3,447 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,447 | The engine in The Ox is a 283, I got it out of a 69 camaro... (it was transplanted from a 63 chevy)
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Originally posted by Nifty 50: As to the 5 to 6 lug problem, I grew up hearing that '53 car front drums will fit right on the truck spindles. Never tried it, so don't know if it is true. If so, it would be a cheap and easy way to avoid hauling two spares. Steve O I don't recall the exact years, but the pre-55 front drums can easily be swapped to the front of a truck at least starting in '41 and through maybe '59. I put '51 car drums on a '41 pickup once. It took a combination of the car and pickup bearings, and some modifications to get the backing plates to fit. Wasn't a big deal. Its about the same work to put a disk conversion kit on instead. And the disk brake parts are a lot easier to find these days too. But if you do the disk conversion you really need to convert to dual master and replumb the brakes at the same time.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jan 2004 Posts: 288 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 288 | Does that mean I have to relocate the mastercylinder? I would like to keep my current brake pedal.
thanks, Chris
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Originally posted by Chris55.1: Does that mean I have to relocate the mastercylinder? I would like to keep my current brake pedal.
thanks, Chris Is that question to me, regarding my dual-master suggestion? When I installed a dual master on my '55 1st I used a kit from ChevyDuty that moves the new master back a bit, and toward the center of the truck an inch or two. No change to the pedal. So does it move? Yes. Do you need to move it to the firewall? No. If I were doing it again I would order the kit from Classic Performance Products and save $15 or so. I believe the parts are identical.
