5 members (Stovebolt48, Rmillerfly, Shaffer's1950, 2 invisible), 93 guests, and 1 robot.
Topics128,050
Posts1,055,758
#168871 05/22/2005 5:31 PM
Junior Member
Junior Member
Hello, I was wondering how to do away with the inner fender braces, "the adjustinable rods from the firewall to the inner fender tops". I have seen many pictures of streetrods that no longer have these but as far as I can tell these are all the adjustment for the fenders and hood line-up. I really would like to keep them, but I am mounting a hydraboost on my firewall and an 80's 4-speed transmission pedal assembly to the other side of the firewall. So the driver's side rod is gonna be in the way. I was just wondering if anyone has ever run across this problem. This is a 49 deluxe mounted on an 83 cab and chassis one-ton with 4-speed 350. Thank you, Rod
#168872 05/23/2005 1:34 AM
Anonymous
Unregistered
Anonymous
Unregistered
ahhhh thats it...It never even crossed my mind that those braces can affect the hood!!! whoa!!! thanks for helping me out by accident wink
#168873 05/23/2005 3:47 AM
Moderator
Moderator
Get a one piece forward tilting front end. grin
But seriously... Good question. I was wondering the same thing. I am already missing one and the fender sags on that side. I would like to eliminate them for a clean underhood look too.
Don't lose your head to save a minute,
You need your head, your brains are in it.
Burma-Shave (1947)
#168874 05/23/2005 3:54 AM
Junior Member
Junior Member
Yeah, me too!! They are seriously in the way! But how do you fix the fender sag?? Has to be braced another way?????
#168875 05/23/2005 6:10 AM
Ugly solution:
1 inch angle along firewall between fenders. Hinge to same along fender. Short turnbuckles between firewall and fender pieces. Basically a stiffer version of the original, allowing a shorter, wider-spaced brace.
#168876 05/23/2005 7:43 AM
Mine were gone when I bought it, and it looks great and the hood closes well
51 Chevy 1/2 ton-Restored
46 GMC 1 1/2 ton-Farm Fresh
