8 members (2-Ton, MNSmith, mick53, TUTS 59, Cletus1950, Peggy M, klhansen, EchoBravoSierra),
101
Mod | | | Forums66 Topics128,173 Posts1,057,041 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2003 Posts: 224 Wrench Fetcher | | Wrench Fetcher Joined: May 2003 Posts: 224 | i was checking out this 60's impala on ebay the other day and saw that it came with a SWEET looking factory tilt steering colomn. it looked just like the colomns that are on the 60-66 trucks with the exception of the tilt. i could be wrong but it looked pretty close, was there ever this option for the trucks as well or has anyone made the switch? | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Became an option for Chevy trucks in 1970.
Fred 52 3600 69 C-10
| | | | | Joined: Apr 2000 Posts: 247 Member | | Member Joined: Apr 2000 Posts: 247 | It didn't come as an option. There are some 67-72 chevy vans that did have a tilt column that will bolt right into the 60-66, including the wiring connectors. | | | | | Joined: Jan 2005 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 112 | I put a 71 automatic column in my 64. Had to change connectors, fabricate shift lincage and make a simple mount. The length of the shaft between the steering box and column is different. If you drill out the plastic pins that allow the shaft to collapse in an accident, you MIGHT be able to slide it to the length you need. | | | | | Joined: May 2003 Posts: 224 Wrench Fetcher | | Wrench Fetcher Joined: May 2003 Posts: 224 | wow 67-72 vans eh? that is awesome, that would be quite a cool modification. i got the three speed on the column. ya think the 67-72 three speed is identicle to the 60-66? everything looks the same to me, except the later column shifters are curved and not straight. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | My '72 C10 has a factory tilt-column, but I understand it was a rare option.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
