5 members (Jon G, Otto Skorzeny, Hanks custodian, dt235sd, 3800GUY), 166 guests, and 1 robot.
Topics128,105
Posts1,056,205
Members48,436
#16848 09/18/2002 10:32 PM
Hello, I rebuilt my brake cylinders and master cylinder, replaced the shoe springs too. The brake pedal seems to return in slow motion. Is there a return spring on the brake pedal arm for a '45 half ton? What gives? Thanks, john.
Do you have too much fluid in the master cylinder?
You should have a return spring for the pedal somwhere by the lower part of the pedal under the cab and going toward the side of the block or the frame close to the exhaust pipe about the level of the top edge of the oil-pan and bottom edge of the block.
I was wondering all that you did to the brake system. can you list your steps and what you used to clean and assemble the work?
new rubber pistons in the master need a little break in I imagine, but the worst offender is usually gack on the master cylinder cylinder walls, a gum that can be sticky and slow things up. Or, a wimpy return spring. As well, I imagine if the ports in the master cyl.piston or housing are restricted by even a tiny speck of debris, then the return will be slow as well.
JKU72
56 3100
68 Suburban
If your pedal rubs the hole in the floor that it comes through it will be slow too. My pedal is slow if I put the parking brake on- the return springs on the shoes are important.
Paint & Body Shop moderator
my brake pedal returns to it's stop slowly, only because the cab has shifted and now the pedal rubs the top of the hole in the floorboard. So a few seconds after accelerating form a stop the brake finally frees it's self from the floor board and BAM!! returns to "normal", then my wife usually asks WHAT WAS THAT?!?!. :confused: huh? what? oh, that noise.... transmission, fell out dear. as I keep driving around the lake. grin
Yes, officer it's licensed.
Didn`t need that part anyway dear grin
.I am still waiting for the details on the job that was done smile
If you are using the stock mc, do not forget the tiny hole between the reservoir and the cylinder. This must be clear to assist rreturn of fluid. There is also an adjustment to make sure the port is open vis-a-vis the piston assembly. Refer to your master shop manual. grin
