| | | Forums66 Topics128,085 Posts1,056,091 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2003 Posts: 331 Member | | Member Joined: Jun 2003 Posts: 331 | I recently took my grill and outside door handles in to be rechromed.I was quoted at $400 canadian to have this done. Does this sound resonable or am I over paying? Thanks in advance: Stuart | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | sounds fair for a grill around here, if they do good work - never cheap unless ya settle for a bad job!
Bill | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Stuart, it depends on the grille you have and what they are going to do to it. Does it need repairs, is it rusty etc? Is it for both the upper and the lower? There was some healthy debates on the subject of who and how much to pay. Have you seen his work? Will he give you a written qoute of what he is to do and when it will be done? What is his warranty policy etc? chome questions and answers Unfortunately there have been several complaints from this vendor, but I think his questions and answers are right on. Do a search on chrome in the archives, I think Ken and Cletis had some problems and concerns. ...g | | | | | Joined: Jun 2003 Posts: 331 Member | | Member Joined: Jun 2003 Posts: 331 | GMONIZ Upper and lower,Repair about 10 small dings and 5 stress cracks, Very little rust.Handles are pitted and he is going to grind smooth Yes I got a written quote. The shop is a very large metal shop and the claim to be the largest facility in Western Canada.They usually don't do small projects and started to recomend another shop.But I think I lucked out because the head plater took intrest and knew right away it was from a 46. I will be picking it up on tuesday or wednesday so I will post pics.Here is before pic. http://pg.photos.yahoo.com/ph/sublime589/detail?.dir=e409&.dnm=6d13.jpg&.src=ph | | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | You better jump all over that deal. That's about 325 US. Apparently there are no "EPA"-type rules in Canada. My '45 grille was completely disassembled and chromed. reassembled with ss fasteners. And it sure didn't cost no 400 bucks! Even if yours turns out to be a crappy job, it'll still look nice for a while. That is quite a deal and you should be signing up immediately! There will be areas of the grille that can't be plated. When you get it back, use some clear paint and touch up those areas right away. It will stop any surface rust from starting. | | | | | Joined: Aug 2002 Posts: 221 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Aug 2002 Posts: 221 | Stuart 999!
The guys are giving you good advice! I had a quote on my 46 grill of over $900. I went with a repro which is no where near the quality of the original.
I've kept the old one in case I find someone that has a price like you have found.
Hope they can do a decent job for you.
Cheers, George | | | | | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | I have heard you can get them done much cheaper in Canada. Other than this has anyone else confirmed this. I don't live far from Windsor.
Tim Sheridan 1947 First Series Chevy 1/2-Ton"Liberty Series" - "Art Deco" - Whatever you'd like to call it. In the Gallery | | | | | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | My '45 grill had some repairs done on upper and lower (ding removal and a little welding). They did a beutiful job for $450.00, and it included polishing that skinny 3 piece trim. I thought that was real reasonable price. I love those grills. | | |
