4 members (Charles in CA, Shade Baby, Hotrod Lincoln, 46 Texaco), 119 guests, and 3 robots.
Topics128,162
Posts1,056,913
Members48,458
#168259 11/30/2004 12:02 AM
Has any one replaced a stock 3 sped with a 4speed.?Is it a direct swap or does the enclosed drive shaft need messing with?A friend has a 4 speed and i already have a hole in the floor board or 3. grin My tranny craped out today and my 51 is my daily driver frown
1942 1\2 Ton
1951 1\2 Ton 55 willys cj-5
1954 and 59 Cushman Scooter
1960 Biscayne Sedan
1965 G/10 panel van
1966 C/30 Grizzly Motorhome
You know you're a 'Bolter when your daily driver is older than you are...
My progress pics
Riding in the Passing Lane
I,ve never done it but I believe it is a direct
swap if the trans. is out of a48-54. You will need
the taller cover to go with it. smile
1972 Chevy c10 Cheyenne Super
Ronnie-I know you'll need a u-joint for the 4-spd. If you want fix your 3-spd., I could donate some parts to the cause.
To be long remembered as he's cruising in
The Passing Lane
Thanks for the info guys.Barry, imight have to take you up on that offer, the wifes been looking for a good excuse to go back to still water.I personally prefer the 3 on the tree as it offers a bit more room in the cab when ive got a kid or two and my two labs in the truck. Im hopeing to pull the tranny fiday and have a peek inside.I cant even hold it in 3rd gear anymore.
1942 1\2 Ton
1960 Biscayne Sedan
1965 G/10 panel van
My progress pics
i've got the 4 speed all the way back to the rear if you need any small parts(might have to wait untill this white crap melts).
i'd send ya big parts but shipping WILL kill ya;)
i miss obscene phone calls...
I did this swap on a '47. You can use a 4 speed from a 1/2 or 3/4 ton but you will need the u-joint cross (tranny side) from the 1/2 ton 4 speed.
Jason
