3 members (Steelonsteel, Otto Skorzeny, 1 invisible), 60 guests, and 2 robots.
Topics128,054
Posts1,055,780
#16816 09/30/2004 3:03 AM
Maybe this is just the way it is but when I get about 1 quart low I can uncover the pump when braking fairly hard, not skidding but more than normal. Also there is one of those round-abouts that going through that too quickly gives a left/right and uncovers the pump too. The pressure goes to zero for several seconds then comes back up. No problem when full. Are there some 235 pans better than others? I have a '61 235 but no telling what the pan came off of.
Thanks, Dennis
40 Chevy 1/2 ton
#16817 09/30/2004 3:11 AM
My 54 eng/235 acts the same way,, I just figured it was norm for these old trucks,guess we will find out from others,,,,,regards...Fred
Redryder pix
My Hotrod
#16818 09/30/2004 3:21 AM
Junior Member
Junior Member
I don't know much about that motor.But you could put a baffel with a flapper on it in the pan an inch or 2 in front of the pump.So when you brake the flapper stops the oil from goin to the front of the pan.give that a thought.No oil pressure is not a good thing. cool
"Life Is all about [censored]! Your either covering it, laughing it off, kicking it, kissing it, busting it, or trying to get a piece of it. Have a good day!!"
