10 members (55shaker, Gdads51, RaNfLaS, Thom75, fonz8261, jay d, TUTS 59, Otto Skorzeny, Jims46, 1 invisible),
83
Mod | | | Forums66 Topics128,288 Posts1,058,546 Members48,491 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2002 Posts: 150 'Bolter | | 'Bolter Joined: Jun 2002 Posts: 150 | What is the theory and dimensions for drilling and countersinking the right side main bed attach bolts with ecentric washers on the 1965 Fleetside SWB? Thanks, Mike | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Check Mar-K's website. I have seen a tech article there before. Additionally, I believe the theory behind the offset hole in the bed mounting washers is to keep it from spinning when tightening the nut from below. The bolt has a carriage head with a square shoulder, however the bolt and washer will spin when tightened, if not for the offset hole and the mortise of the washer to set flush with the surface of the bed wood. Best of luck with your wood replacement. | | | | | Joined: Feb 2002 Posts: 2,898 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,898 | | | | | | Joined: Jun 2002 Posts: 150 'Bolter | | 'Bolter Joined: Jun 2002 Posts: 150 | Now that is what I was looking for. A few days too late, but what I did will work. I'll post when I get it done. Thanks, MIke | | | | | Joined: Feb 2002 Posts: 2,898 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,898 | ya shoulda asked sooner!
Hehehe.
-W | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I countersunk my washers and bolts with a paddle bit then had my 11 year old son sit in the bed with a box wrench while I tightened them up from below.
It worked well. Gave us a little father/son time.
Dennis -there is nothing stronger than the heart of a volunteer-
