0 members (),
329
Mod | | | Forums66 Topics128,168 Posts1,057,100 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 70 | I just got the rubber strips that go inside the "track" inside the cab at the door openings. What is the easiest way to install these? Should I just start at one end and slide them in, or "shoe horn them in with a screwdriver? Any better ideas are appreciated.
Thanks! | | | | | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | MJ; Do a search on this subject. There is a lot of information and suggestions. The gasketing seals you are speaking of are called a windlace. There are two different types but as you stated, you should have a track in your later model. Be prepared to use a lot of lubricant but the biggest help you can do is to use a wide flat blade screwdriver to "open" up the tracks. Then you need to scour out the tracks with the screwdriver blade or other suitable instrument to remove any old dirt or other crap that will hinder your replacement seal. Then, with the windlace, start at one end (I started at the rear of the door frame) and pulllllll it around using lots of the lubricant. If it slips out of the track, close that section up a bit with a light hammer blow. Just enough to snug it but not impede its progress. Be patient and you'll get it done. | | | | | Joined: Jan 2007 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 70 | Thanks a lot Geezer,
That worked like a charm. I now need to install the horizontal window felts inside the window trim. I got the staples out and need to decide if screws are the way to go. (I did a search like you said and found some discussions on the topic). My new ones aren't curved like the originals, but I imagine they'll work. Will this keep the rain out of the bottom of my door? | | | | | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | It's been a while since I did my felts but I believe that I pulled the staples, cleaned up the surfaces well and used construction adhesive form Lowe's to glue them back on. Put spring loaded clamps all along the trim, cleaned up any ooze that came out under the clamp pressure and left them alone for a week. Worked like a charm and no screws involved. Rain will still get in the bottom of your door. You have drain holes in the bottom of the door itself so make sure that they are clear. Before I put my plates and cardboard covers back on my doors I sprayed the crap out of them with rust preventative just to keep it at bay but then my truck is garaged. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Another helpful hint on the windlace installation. Cut a piece about an inch long and run it through the track. Then you can easily tell where the track needs to be spread. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Or you can do something like this if you’ve a mind to. That is if you want to do it the hard way and keep it original. http://rides.webshots.com/photo/2654795910098611668GrAeDg Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | I just put new door windlace in my 54 ... and then removed it and sent the truck off to the painter's. When it comes back from paint, I'll be installing the windlace again. It wasn't as difficult as I thought it was gonna be! [b]Here\'s[/b] My Pics and Explanations
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | |
