| | | Forums66 Topics128,062 Posts1,055,851 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | I posted this over on doors but got no replies. Please help!!Getting back to working on the doors of my 49 burb. I bought preformed felt window channel LMC and fits great. I did a search and looks like 3M Super Adhesive is recommended to secure to the metal channel inside the door. Is this enough with no screws? etc to hold it in place? Any additional tips appreciated. Thanks
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
| | | | | Joined: Mar 2005 Posts: 58 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 58 | Yes it will hold. Follow the directions on the tube. I think you have to put it on both surfaces and believe me it will not move once you place it. I just did both side windows on my 57 two months ago. No problems. The felt is in a roll from classic parts. What a trip getting that in place!
Kevin | | | | | Joined: Mar 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 388 | When I removed my metal/felt channel I had to remove small screws at each end of the strip. Mine came out of a '48 Good luck!
Mike | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | I opted to use small screws to secure mine. Worked out well.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | I used both , the black adhesive an just couple screws to here an there to to keep it tight. | | |
