| | | Forums66 Topics128,037 Posts1,055,466 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i am replacing all the door rubber. is there a rubber piece that goes along the bottom of the door and what is it called. i ordered what i thought was a complete kit but there was nothing for the bottom of the door. i think that i have to order a set of rubbber for along the cab ledge where it meets the carpet. if someone could post a picture i would appreciate it. i am a little confused by the pictures in the catalog and what they call them. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Mar 2005 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 144 | I just ordered a set for my 46 and I believe it's called lower cab windlace. It runs along the lower side of the cab and sticks very slightly above the floor of the cab. Bob T | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | thanks bobt, i did a little more research and found a picture that i could understand. what happened the body man cut the rubber and cut off what should have gone on the bottom. i think he can repair it, but if not i will order a new one, they aren't much. live and learn. not a big deal i still have to order the retainer strip and some other parts. ron
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I'm a little confused Ron, the door rubber for the AD starts on the bottom about 14" from the front piller and runs all the way around in one continuous piece all the way around till it meets itself back on the bottom. There is a single lower cab windlace rubber that is the length of the door opening retained by a strip at the outer edge of the floor. Hope that jogs your memory. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | denny, you are correct. but i am talking about the doors. the body man called back and he had cut the seal think it ended at the bottom edge of the door. he still has the pieces and will replace the. ron
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | OK i am confused ! anyone got a pic ..of the lower door on there truck an how the trim holds the bottem pc of weather strip ..i purchased new S.S trim but an not sure on were it goes .. HELP ????????? | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | the problem area that i am aware of is the door's leading edge at the upper hinge area? :confused_smile:
any one else know
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Had this uploaded this morning Ron but my connection was so slow I had to wait till this afternoon to finish it up. I think this should show you what it looks like. http://rides.webshots.com/photo/2395785850098611668qDSomp Denny Graham Sandwich, IL
| | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Hey, Denny.
I never saw that trim piece before! Where did you buy it and what part # is it?
I'll be doing my door rubber (again) when my truck comes back from paint and that trim piece looks like a great addition to the project. I wonder why I never noticed that when I bought my other kits!?
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 |
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | tc, is that like winning the gold medal and having it bronzed????????? ron
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Tim's got her takin' care of Alan. When you lay it up there you would swear that it taint gonna fit. It has to compress the seal quite a bit. I got mine from Chevy Duty, SS. Now if they had only used one on the front between the hinges we'd have it made. Denny Graham Sandwich, IL
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | i'll read thru all this again today but on a sightly different thought here ... does anyone have a photo of the door's bottom edge that shows the metal trim piece in place??????? my body shop guy rebuilt the door bottom and I have no reference (holes) to locate the metal edge piece thanks guys
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | The holes are 1” up measured from the outside of the bottom edge of the outer skin. Just even up the end holes. It looks like more in the picture but it’s not. http://rides.webshots.com/photo/2395785850098611668qDSomp Denny Graham Sandwich, IL
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | thanks denny i missed the link half way up the page i'll get working on the missing holes tonight cheers
