7 members (BCBill, Gdads51, Lightholder's Dad, joe apple, Hawkman, greenie-reddy, TUTS 59),
190
0
Mod | | | Forums66 Topics128,101 Posts1,056,176 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 108 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 108 | Recently I purchase an aftermarket cardboard type replacement headliner for my 1951 Chevy Truck. It is the standard 2 piece type. I noticed that the forward headliner panel is not pre-drilled or pre-marked for the installation of the sun visors. Each visor mounts to a large centered hole for the pivot post assembly and three mounted screws into the metal windshield frame. Does anyone have a TIP or TECHNIQUE for accuately locating and marking the forward headliner panel before drilling. The last thing I want is to mark, drill, and mount my visors incorrectly which could result in a droop or mis-fitting headliner. It appears as though it will be a "one shot" deal, right or wrong! Thanks in advance. Will
Best Regards Will
| | | | | Joined: Jun 2007 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 110 | if you have the old one carefully remove it and use as a pattern??? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Will,
This might be the hard way, but it worked for me. I bought six 1" screws that fit the sun visor holes in the roof. I cut the tops off the screws, ground a rounded point on the top of each screw, and cut (with a Dremel Tool) a slot in the top of each screw (a screw driver slot).
I then screwed them into the mounting holes, allowing them to sit "proud" (outwards) for about 1/4". The headliner was then dry-fitted into place and pressed against the screw heads. After removing the headliner, it was an easy matter of drilling the three holes on each side and placing of larger hole between the screw holes. This technique has worked fine for me (and, I have gotten three uses out of that set of "fitting" screws.
Tim | | | | | Joined: Aug 2006 Posts: 108 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 108 | First Post: The truck was missing a headliner. Second Post: That sounds like a good idea! I will try your technique....Thanks to both replies.
Best Regards Will
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Tim’s transfer screws tip also works good for locating the arm rest holes in the AD door trim panels. I know there has been some discussion about the templates that they send with the arm rests being way off. Here’s a couple of pics just put the headliner and visor in the picture instead of the door panel and arm rest. http://rides.webshots.com/photo/2228649540098611668WPYZxr Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | I used a very sharp ice pick to find and make the holes in the headliner. If you look at the sunvisors, they are rather large with a big hole in the center. Poke a hole in the big center hole on each side after mounting the front headliner part then likewise with the three screw holes on each visor. It was easy but go slow. | | |
