| | | Forums66 Topics128,049 Posts1,055,638 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 3 Junior Member | | Junior Member Joined: May 2007 Posts: 3 | Has anyone gone through the process of restoring a vintage steering wheel. I have read an article on the process of filing cracks, filling and re-painting with a flex additive but have not gone through the process myself. Are there any other considerations of additional procedures that are needed to restore a vintage steering wheel? | | | | | Joined: May 2007 Posts: 275 Shop Shark | | Shop Shark Joined: May 2007 Posts: 275 | Don't worry about the flex additive. The properties of the flex additive only last for several days to weeks.
It's mainly good for polyeurathane bumpers. So the paint bends while your are getting the bumper mounted to the body. If you notice, those bumpers start showing spider cracks after a while even mounted firmly to the body. And if you bump anything, you get the cracks right away.
The easiest way to restore the steering wheel is to clean out the cracks and make a "V" cut into the crack. Fill it with body filler, prime, sand and finish just like you would with a car body. It'll look great and last a long time.
If you like leather steering wheels, go to Wheelskins.com and take a look at their covers. I have one on my car and looks like factory. I love the way it looks and so does everyone that has seen it.
Frank
No better smell than that of fresh paint. I've been building and painting cars/trucks for 47 years. Not gonna stop now. http://www.coxcustomcars.com/ | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Agree with Frank on veeing out the cracks. I used JB Weld to fill cracks and then primed. I still have some hairline cracks I figure I'll use some glazing/Icing to finish up. Dan | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | I used JB Weld on my steering wheel cracks and it was great -- quick and easy! See Here Then I covered my steering wheel ('75 Caddy tilt) with elk leather: See Here
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | I also used the v grinds on cracks in my '42 wheel...remember to grind to the core (not through). I used POR 15 Epoxy bars (mix two parts together)...worked extremely well. You can smooth the putty with water so it really cuts down on sanding. File, sand and wet sand, prime & paint ..works great! | | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | What kind of paint are we talking about. I know they make steering wheel paint. Are you guys using that ro soemthing else, acrylic, epoxy, enamel?? | | | | | Joined: Mar 2007 Posts: 12 Junior Member | | Junior Member Joined: Mar 2007 Posts: 12 | I used a Dremel tool to make the cracks bigger and then filled them with bondo, sanded and repainted the wheel. Looks brand new! | | | | | Joined: May 2007 Posts: 275 Shop Shark | | Shop Shark Joined: May 2007 Posts: 275 | You can use whatever paint your want. I would go with bc/cc. Think how great the wheel would look finished the same color as the body.
Clear is very durable.
Frank
No better smell than that of fresh paint. I've been building and painting cars/trucks for 47 years. Not gonna stop now. http://www.coxcustomcars.com/ | | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | I suggest spraying the wheel with adhesion promoter, like 'bulldog', before painting.
| | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | I've tried a variety of paints on the wheel and never seemed to get them to hold up for any length of time. I finally wound up with SEC spray vinyl upholstery paint.....it's no bc/cc but it's available in a broad spectrum of colors, it goes on smooth, doesn't look like "paint", and best of all it stays on....no flaking or cracking. Hope this helps.
Dave | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | make a "V" cut into the crack. Fill it with body filler, prime, sand and finish bondo simply does NOT hold to the wheel material my.02
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
