0 members (), 146 guests, and 2 robots.
Topics128,162
Posts1,056,939
Members48,458
Apprentice
Apprentice
Not sure if this is the right place to post this, but here goes:
My window regulator on the driver's side door in my 1972 1/2 ton pickup went kaput, so I have a new one from LMC. However, I can't get the old one out. The forward window track sits directly outboard of the regulator so there is not enough room to get the window crank drive shaft out of the panel hole. I losened the track but it will not give enough to let me get the regulator out of the hole. The regulator itself is broken and I cannot crank the window up or down. It is stuck in the up position.
Does anyone have a 'how to' on the replacement of the window regulator for this truck? I could sure use the help!
Thanks!
Bolter Rush, Cave Springs, AR
1954 Chevrolet 4400 Flat Bed Dump, 1972 Chevrolet long bed.
Email: mikeshahan1960@gmail.com
try this link below on how to but they say lower the glass if you are replacing the regulator can you cut the old one (Dremel Tool, Hacksaw) and remove it.
window regulator
Remove door panel, remove vent window, this will allow glass to slide forward & off of regulator. Remove bolts holding regulator to door.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
Apprentice
Apprentice
Thank you guys. The link to Autozone was very helpful; it told me what I needed to know. (Shows you how little I know about these things since I didn't know Autozone had that!!) The issue is definitely the inability to lower the window, I can see that now. So, will have to figure out what to do about that. The dremel may be the answer. smile
Thank you again!
Moderated by  ndkid275, Phak1
