| | | Forums66 Topics128,153 Posts1,056,849 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2000 Posts: 27 Apprentice | | Apprentice Joined: Nov 2000 Posts: 27 | Not sure if this is the right place to post this, but here goes:
My window regulator on the driver's side door in my 1972 1/2 ton pickup went kaput, so I have a new one from LMC. However, I can't get the old one out. The forward window track sits directly outboard of the regulator so there is not enough room to get the window crank drive shaft out of the panel hole. I losened the track but it will not give enough to let me get the regulator out of the hole. The regulator itself is broken and I cannot crank the window up or down. It is stuck in the up position.
Does anyone have a 'how to' on the replacement of the window regulator for this truck? I could sure use the help!
Thanks! | | | | | Joined: Apr 2007 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2007 Posts: 38 | try this link below on how to but they say lower the glass if you are replacing the regulator can you cut the old one (Dremel Tool, Hacksaw) and remove it. window regulator | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Remove door panel, remove vent window, this will allow glass to slide forward & off of regulator. Remove bolts holding regulator to door. | | | | | Joined: Nov 2000 Posts: 27 Apprentice | | Apprentice Joined: Nov 2000 Posts: 27 | Thank you guys. The link to Autozone was very helpful; it told me what I needed to know. (Shows you how little I know about these things since I didn't know Autozone had that!!) The issue is definitely the inability to lower the window, I can see that now. So, will have to figure out what to do about that. The dremel may be the answer. Thank you again! | | |
