Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Peggy M, MNSmith), 240 guests, and 4 robots.
Topics128,282
Posts1,058,495
Members48,490
#16597 11/20/2003 11:37 PM
After running my '59 for a couple of months, yesterday I started it and it was sputtering and trying to die, I saw that the carb was POURING out fuel out of the throttle shaft!!! You guys think that a re-build will fix the problem or is a new carb the answer? (The 235 w/ 1B Rochester was very rich before and I couldn't get the soot of the plugs) The truck had sat in my Dad's barn for 3 years before I had it shipped out here. Thanks for your help in advance.
I know you believe you understand what you think I said, but I'm not sure that you realize that what you heard is not what I meant!
#16598 11/21/2003 1:01 AM
Yep, you need to rebuild it. Most likely the float is stuck and it is flooding out.
Paint & Body Shop moderator
#16599 11/21/2003 2:10 AM
I agree that a rebuild is in order, but you probably need to bush the throttle body shaft while you're at it. They have a bad habit of throttle body wear, and allow air to suck in where they shouldn't.
Fred
52 3600
69 C-10
#16600 11/21/2003 3:47 PM
Y
Y Offline
I had the same problem on my '61 Apache. A "rebuild" will not generally include re bushing the throttle shaft, as it didnt on mine. I was able to locate a complete used "throttle body" (the cast iron bottom part, that the shaft is in) from one of the vendors for around $20.00 plus shipping. I'm figuring you cant get one rebushed for that, but then again, I couldnt find anyone that was willing to do it at all in my neck of the woods. Not sure about rules concerning posting vendor info here, so contact me via e mail if you need the info. [email protected]
