5 members (diseasel, Johnny Rib, Nick in Manitou, Hotrod Lincoln, Hanks custodian), 102 guests, and 2 robots.
Topics128,035
Posts1,055,559
#165943 04/26/2007 5:47 PM
I need to get a new knob for my 3 speed shifter . Howare they attached? Glue?
#165944 04/26/2007 7:22 PM
They're a press fit. The splines on the end of the shift lever are supposed to hold it on. Just tap it on with a ruber tipped hammer.
Bill Burmeister
#165945 04/26/2007 7:22 PM
Newer styles are just threaded and screw on and off ... after you get yours off, if the end of your shifter-shaft is the right size, maybe you could tap it with threads and put a newer knob on?
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
#165946 04/30/2007 11:56 AM
It Is press fit, I put my new one in some hot water and pushed it on the splines,when it cooled off it is on there for good.
Mr.Giant
1953 Chevrolet 3100 in the Gallery
1959 GMC 860 Single Axle Truck Tractor in the Gallery
#165947 05/03/2007 2:54 PM
5/16'' sae thread
if my memory surves me is pretty standard for shifter knobs in general
Jim & Caroline
#165948 06/26/2007 12:30 AM
Junior Member
Junior Member
Hey fellas,
I got a 1963 fleetside... and wanted to change the knob on my three on the tree. I've tried playing with it to see if it is screwed on but seems to just turn and turn. So if I heard right, you guys think it is just glued on? Any suggestions on how to get the old one off and replace with a new one?
I'd appreciate any suggestions. I've tried to take it off with little success.
#165949 06/26/2007 1:41 AM
My 66' had an old shifter knob so when I rec'd the new one, I just cut the old knob off with a dremel tool and glued the new one on. Good luck
Mike
#165950 06/28/2007 6:48 PM
Junior Member
Junior Member
I'm guessing it is just 43 yr old glue. So I'm going to try to pull it off once the heat picks up around here. Might make it a little more flexible and try to pry that puppy off. Thanks for the insight though. I wanted to put a new knob on or a custom knob of some sort. A outfit here in Southern Cali called mooneyes has some cool knobs to try. Not too pricey either.
#165951 06/30/2007 2:34 AM
If it's glued on now...maybe heat it up with a blow dryer. That may loosen up old glue. Maybe grip it with some vice grips...tap upwards under the vise-grips with rubber mallet forcing it up off the metal rod. I have newer tranny so my shifter knob is the thread (screw) on type.
Dean
Moderated by  ndkid275, Phak1
