3 members (dt235sd, Tom McGrath, 55shaker), 94 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
1951 3100 with vacuum wipers. Can someone clarify how to install the link rod from the vacuum wiper switch to the vacuum motor control lever? I have new grommets and a new link but cannot determine which end of the link goes into which hole. One end of the link has a single 90 degree bend, and the other has 2 90 degree bends. One grommet is a donut type grommet, the other is a push in plug type with a short nipple on the bottom. Thanks in advance.
Best Regards
Will
Try this link Will, the little nipple is pulled off the bottom of the link but I think you can see how it goes.
http://rides.webshots.com/photo/2112496490098611668sFdxlJ
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
PERFECT !!! Thanks a million
Best Regards
Will
thanks denny, you da man. My project does not have the little lever so I'll be hunting one..or making one from your pic! Thanks. I should have you a "care package" in the mail the first of next week.
Which lever that be Munk, the one on the motor or the one on the Switch??
Denny G
Denny G
Sandwich, IL
The one that goes from the switch to the motor....heck, i better look. I may need more? I'm sure the one from the switch is missing though. I just pulled all that out about 3 weeks ago but have short memory!! I'll have to look. I blasted and painted the arms and have it all in a box.
Moderated by  ndkid275, Phak1
