| | | Forums66 Topics128,074 Posts1,055,911 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 108 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 108 | 1951 3100 with vacuum wipers. Can someone clarify how to install the link rod from the vacuum wiper switch to the vacuum motor control lever? I have new grommets and a new link but cannot determine which end of the link goes into which hole. One end of the link has a single 90 degree bend, and the other has 2 90 degree bends. One grommet is a donut type grommet, the other is a push in plug type with a short nipple on the bottom. Thanks in advance.
Best Regards Will
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Try this link Will, the little nipple is pulled off the bottom of the link but I think you can see how it goes. http://rides.webshots.com/photo/2112496490098611668sFdxlJ Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Aug 2006 Posts: 108 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 108 | PERFECT !!! Thanks a million
Best Regards Will
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | thanks denny, you da man. My project does not have the little lever so I'll be hunting one..or making one from your pic! Thanks. I should have you a "care package" in the mail the first of next week. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Which lever that be Munk, the one on the motor or the one on the Switch?? Denny G
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | The one that goes from the switch to the motor....heck, i better look. I may need more? I'm sure the one from the switch is missing though. I just pulled all that out about 3 weeks ago but have short memory!! I'll have to look. I blasted and painted the arms and have it all in a box. | | |
