7 members (55shaker, Woodcmiami, Rusted Nut, Gdads51, CuzzFuzz, Still At It, 1 invisible),
156
Mod | | | Forums66 Topics128,138 Posts1,056,441 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 108 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 108 | Where are the window stop bumpers located inside the window mechanism? 1951 Chevy 3100 Pickup.
Best Regards Will
| | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | There spot welded inside the door about half way down. If you look at the inner door you should be able to see 4 spot welds that hold it. | | | | | Joined: Aug 2006 Posts: 108 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 108 | Wilbur: I am refering to the "rubber" window stop bumpers that can be purchased from the suppliers. They are about 3/4" square with a tapered nipple on the back side for fitting into a hole (much in the same way as the hood or door bumpers do).Any ideas?
Best Regards Will
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Will - number 9 in this diagram , so it hits the glass assembly when cranked all the way down Bill | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | The '50 stop is different than the '51 Wilber because the regulators are different and the window is smaller. The stop is on a 4" square bracket on the '50 easily reached through the bottom access panel and its located on the regulator arm on the later ones again should be accessible through the panel. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | | | | | | Joined: Aug 2006 Posts: 108 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 108 | I am not sure about the answers provide? Let me clarify my question. I am wondering where specifically the small square rubber window stops (bumpers) are installed insde the door regulator assembly of my 1951 truck. The rubber stops can be purchased in most parts catalogs and are the items mentioned in Extreme Gangster's diagram. They have a small tappered nipple (plug) on their back side to fit within a hole similar to door or glove box bumpers.Do they fit to the window's lower metal track? on the regulator arm? or maybe on a bracket welded within the door assembly? Gotta be a pre drilled hole for them there somewhere????
Best Regards Will
| | | | | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | There's a bracket spotwelded inside the door.With the regulator out, you should see it.
Bob | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Will, you don't have to disassemble anything other than removing the lower access panel. stick your arm inside and feel around, there is a hole or an old bumper right where the arrow points in the link that Bill posted if it is a '51 door. If you don't have the vent windows than someone switched doors on ya and it would be in the bracket that Wilber, Bob and I mentioned earlier. And again, you can reach that easily also from the access hole and feel the old rubber or the hole in the bracket if its missing. Also a good investment might be in a flashlight and inspection mirror or stick your digital camera inside there and snap a bunch of pictures so you can see what it looks like inside! Denny Graham Sandwich, IL
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Did ya ever find those bumpers/holes Will??? Denny G
| | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | I've got the bumpers but I've not located the holes... I've got to get a flashlight! | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I wasn't kidding bout the digital camera Virginia, it works great for getting a real good idea of what the inside looks like. You become the incredable shrinking man, able to crawl inside the door. I also took a few dozen under dash photos so I could sit at the computer and figure out what needed to be done there, beats standing on your head for an hour and trying to remember it all. Denny Graham Sandwich, IL
| | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | I'll try it in the morning when I get to the shop. | | |
