4 members (Otto Skorzeny, Hotrod Lincoln, msmall, Peggy M), 59 guests, and 3 robots.
Topics128,057
Posts1,055,815
#165692 03/16/2007 11:48 AM
Just received my interior kit from Hampton Coach for my 1938 HC. Everything looks pretty straight-forward, except the windlace kit. My truck had no interior except the springs, so I can't even rely on my failing memory. The kit came with four pieces of windlace, the longer two are obviously to install under the moulding around the door openings. The two shorter (44") pieces I suppose go under the moulding around the top of the doors.
The 44" long windlace isn't long enough to door the entire upper half of the door, so where does it start and end? Anyone got a photo they could share?
"You are only young once, but you can ALWAYS be immature!"
1938 Chevrolet H/C 1/2-Ton
#165693 03/19/2007 1:25 AM
lobo,
Not sure if you got your cab sealed up yet, but if not, the two short pieces (at least on a 46) go between the rocker panel and the cab. The top of my rockers had a little slot for holding the windlace. The doors on my truck even had a little line worn across the bottom of them from the seal rubbing on them all those years.
The long pieces went around the door opening and between the dash and the door frame. The door stops have to be installed before you install the windlace, holddown strips and kick panels.
Again, not sure what goes into a 38 interior vs a 40-46...
#165694 03/19/2007 11:41 AM
Thanks for the reply. SO, the windland starts at the dash and goes around the door opening? Does any windlace actually mount on the door or is it all installed on the door jamb?? Checked out you photos...NICE '46!
#165695 03/20/2007 5:36 PM
lobo,
Back to front might be easier to explain..The windlace starts at the bottom rear of the cab at the door opening, goes up the cab, around the top of the door opening, down the front pillar, around the dash and then down to the bottom of the front of the door opening. On my 46, there is a strip that holds the kick plate and the windlace in place.
The windlace kind of snakes past the dash on my 46...
Hard to explain...
Click on this link and it will show how it goes past the dash. The angle of the pic does not show how it goes past the dash real well, but you should be able to see that is continues on to the bottom of the cab...
pic from the driver side looking to the passenger side
#165696 03/21/2007 11:36 AM
That answers my question perfectly!! You sir are a gentleman and a scholar (dang few of us left).
Thanks again..
Moderated by  ndkid275, Phak1
