| | | Forums66 Topics128,032 Posts1,055,519 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 25 Apprentice | | Apprentice Joined: Apr 2005 Posts: 25 | Any easy way to install the head liner retaining rubber in the roof of my 56 Chevy PU? I've washed the soap looking material off the rubber, that may have been a mistake. Is there a material I need to apply to the rubber to allow it to slide into the roof? Maybe talc? I thought of liquid soap but believe it would leave a residue. Thanks in advance. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | If you use anything, try a silcone type lube. Syl-Glyde brand worked fine for me. You can get it from Napa. It doen't take much, just a thin film will do.
Bill Burmeister | | |
