4 members (Bill Hanlon, Otto Skorzeny, gswbbc, dt235sd), 83 guests, and 3 robots.
Topics128,047
Posts1,055,532
Members48,424
#165556 02/28/2007 1:22 AM
For a '54 GMC, I bought door panels and fasteners. The fasteners are 'snaps' not screws, and they don't seem to want to fit into the holes in the door. Is there any magic for inserting these? I feel like if I push too hard I'll break the things.
Any help would be appreciated.
#165557 02/28/2007 1:49 AM
I know what you mean I have a 54/3100 and the PO used monster sheet metal screws so the snap in type would just shake out. I bought 1953 model washers and screws and I will thread insert the holes to accept the screws. Those snap in things are a real PIA if you hit them too hard they fly or break....good luck, Steve :mad:
#165558 02/28/2007 6:18 PM
Thanks, Steve. So aren't the existing holes in the door too large to hold the screws that you bought?
#165559 03/01/2007 5:42 AM
YEP...that is why I own a rivet nutter...drill out hole for a rivet nut.. pull handle and instant thread in hole...there are three things that I could not do without while putting this truck back together a welder, dremel motor tool, and a rivet nutter...you can build anything with these three tools...Steve
#165560 03/01/2007 5:45 AM
Or,,,,,,,,just drill a hole a litle to the side of the existing"wrong" hole and use a sheet metal screw with a finish washer. Very simple.
Marty
#165561 03/01/2007 5:50 AM
Marty....I know that you would not do that on your fine ride...besides my PO while drunk made the holes way big with the screws. He used a big pan head so he did not have to use the cup washers....Oh man! Steve
#165562 03/01/2007 8:05 PM
Steve, so is a "rivet nutter" different from a pop rivet tool?
#165563 03/02/2007 4:24 PM
YEP... its a heavy duty tool the rivets range in size from 8/32 / to 1/2 inch fine or course thread. You can buy all types of thickness and special types. Do a google Mc Master-Carr and look for rivets you will see what I mean, they have the tool and rivet nuts.THANKS, Steve
Moderated by  ndkid275, Phak1
