0 members (),
132
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | For a '54 GMC, I bought door panels and fasteners. The fasteners are 'snaps' not screws, and they don't seem to want to fit into the holes in the door. Is there any magic for inserting these? I feel like if I push too hard I'll break the things.
Any help would be appreciated. | | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | I know what you mean I have a 54/3100 and the PO used monster sheet metal screws so the snap in type would just shake out. I bought 1953 model washers and screws and I will thread insert the holes to accept the screws. Those snap in things are a real PIA if you hit them too hard they fly or break....good luck, Steve :mad: | | | | | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | Thanks, Steve. So aren't the existing holes in the door too large to hold the screws that you bought? | | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | YEP...that is why I own a rivet nutter...drill out hole for a rivet nut.. pull handle and instant thread in hole...there are three things that I could not do without while putting this truck back together a welder, dremel motor tool, and a rivet nutter...you can build anything with these three tools...Steve | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Or,,,,,,,,just drill a hole a litle to the side of the existing"wrong" hole and use a sheet metal screw with a finish washer. Very simple. Marty | | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | Marty....I know that you would not do that on your fine ride...besides my PO while drunk made the holes way big with the screws. He used a big pan head so he did not have to use the cup washers....Oh man! Steve | | | | | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | Steve, so is a "rivet nutter" different from a pop rivet tool? | | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | YEP... its a heavy duty tool the rivets range in size from 8/32 / to 1/2 inch fine or course thread. You can buy all types of thickness and special types. Do a google Mc Master-Carr and look for rivets you will see what I mean, they have the tool and rivet nuts.THANKS, Steve | | |
