2 members (HandyAndy, mick53),
78
Mod | | | Forums66 Topics128,050 Posts1,055,646 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Home Depot and Lowe's in my area don't carry anything like "peel-n-seal" or the others. Their web sites won't bring them up. I live where a 1/4" of snow is considered the "big snow" of that year. OK, now what do I do? Tar is not an option. Surely someone out there works in an area where a product that has sound deading and heat transfer blocking capabilities is available. If I have to buy "Dynamat" I won't be able to afford to put go juice in my ride. Help!
| | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | My Lowes didn't have it either. I talked to the manager and he ordered it for me thru Lowes. In fact I ordered it in a 3' wide roll. | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Coach-frank, Who the heck make it? Do you have a part number? What it look like? Web site? So many questions, so little time. Thanks
| | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | As I mentioned before....most aluminum fabricators...(screen rooms, car ports) sell the rolled "tape" 3" wide, that is used to seal the seams between 5' wide insulated aluminum roof panels. I've used it throughout my truck...it's easy to use small pieces to do the inside of the doors. Also used it overhead on the roof...no sagging. It has a white vinyl skin, sells for $13.00 a roll and it takes 2-1/2 rolls to do all the cab and door surfaces. The 12" stuff I got from our Home Depot was a pain to apply and smelled like tar.
BTW...it also works...no twang when you close the doors. Hope this helps.
Dave | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | Peel & Seal self stick aluminum roll roofing, Confair Products, PO. box 2715 Glenview, Il. 60025 1- 800-333-6700. Got it straight from the box it came in. Lowes ordered it for me thru their special order service. 36'x 33.5' size, Did the whole truck with lots left over. | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Thanks to both of you'll and the forum for helping us pursue our own style of madness.
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | check w/ a stereo shop that does auto installation or a big auto super or hot rod store it does not take much to kill the tin sound but some think that the single or double sided heavy foiled outer w/ jute material inside is true sound deadening material, that helps kill the tin sound and acts as insulation, products like Dynamat kill sound or that tin noise but do nothing for insulation.  some of the big box store roofing supply products give off a chemical when it gets hot inside the cab during summer. as far as the tin foil tape go to a heating and A/C company. it's called furness tape used in that industry. you may find a do it ur-self type heat/ AC company and can buy it that way.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Feb 2006 Posts: 24 Apprentice | | Apprentice Joined: Feb 2006 Posts: 24 | Hello, Contact me at my shop toll free in the U.S. at 1-800-223-1141 . I do upholstery for a living and restorations. The most afforable and best product we use is the Heat Shield material. Good sound deadner and aluminum faced on one side. I can email you a picture of the material and information ........ I carry large rolls of the Heat shield material in stock, as well as the aluminum tape. My website is www.aglassenterprise.com hope this helps. | | | | | Joined: Feb 2007 Posts: 15 New Guy | | New Guy Joined: Feb 2007 Posts: 15 | Beltfed
Check your local roofing supply, it is a common product with them.
Saba | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | I used a product (same as Peel-N-Seal) called Quick Roof -- my notes on it are Here
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | |
