6 members (lumbersawyer, Otto Skorzeny, TeW, MickeyP, Brian Moore, 1 invisible), 96 guests, and 1 robot.
Topics128,049
Posts1,055,653
#165466 02/14/2007 7:57 PM
In my 53 I have the red turning handle attached to a rod that goes to the firewall which connects to a flow controller. It does not turn. Is there a trick to these things? Do I take the bracket off the bottom of the dash board and the rod will come off the flow controller? Will this flow controller come out of the fire wall? Does it come out into the engine compartment?
TIA
Dennis
#165467 02/15/2007 1:52 PM
the control rod is held on by a c clip and a spring. it should turn but does have a detent to hold it in place. may be rusted. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
#165468 02/22/2007 5:57 PM
id look under the dash where the rod go's into the valve and fog her down with a rust buster let it set it shoudl turn, freed a stuck intake flapper valve overnite with it,
#165469 03/05/2007 1:06 AM
If you remove the two screws from under the hood the valve can be removed by turning it and pulling inside the cab.
TIGHT IS TIGHT,TOO TIGHT IS BUSTED
Moderated by  ndkid275, Phak1
