1 members (Hotrod Lincoln),
118
Mod | | | Forums66 Topics128,093 Posts1,056,474 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | Been carpeting the 53 last 2 days. Tried using industrial strenth velcro to secure to the floor and firewall. Stuff works great. This is the type with adhesive on both sides. Used it in the corners, and top of the firewall. Can remove it by just pulling it apart. Found out you can't glue it to the jute backing though. Must go directly to the back of the carpet. Holding power of the adhesive to strong for the jute. Bought it at a fabric store, by the yard. Not cheap, but a lot less messy than glue. Plus you can re-adjust the carpet to get out any bumps. | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Was wondering how wide it was....assume it is on a roll? Sounds like it might have some other uses also. Dave  | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | About an inch and a half wide. The sales person cut it off a roll to the size we wanted. I bought 2 yards worth. I think it was $7.00 a yard. | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | That's what I'm looking for.....thanks for the info. Dave  | | |
