7 members (69 coupe, Gdads51, Phak1, jmoore, TUTS 59, 54farmtruck, 1955 1 Series),
91
Mod | | | Forums66 Topics128,188 Posts1,057,329 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 25 Apprentice | | Apprentice Joined: Apr 2005 Posts: 25 | What adhesive is recomended to attach a ABS headliner to the inside roof of my cab? Thanks in advance | | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | HI.... I'm just about ready to install my one piece ABS liner...and hope you get a reply from somebody who has installed one...I just finished my firewall and floor so next the headliner...mine will remain black in color its going on my 54 3100 and any suggestions as how to install it would be most welcome...Steve | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | I don't know if it was correct but I used spray contact cement from a rattle can with good results so far. | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | I made my own abs plastic head liner and I didn't glue it at all. Mine is secured by the rear and front trim pieces. The sides are secured by the weather stripping. We glued a piece of suede over the abs plastic, but not to the inside roof. Here are some photos. http://s159.photobucket.com/albums/t160/sworden73/ | | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | Coach-Frank... for some reason your photos can not be accessed. On my 54 cab I have a retainer strip at the rear and no trim piece at the front windshield. As I understand it the one piece headliner tucks in behind the windshields rubber strip which also holds the windshield in place?....Do you or anyone else know if that is correct? I have never seen one of these ABS headliners installed and the instructions leave a lot to be desired and we will not use any glue also....Thanks, Steve | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | Steve, try the photos again, I think I for got to log out on the photobucket site. | | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | Coach- Frank..got the pictures and the job looks very nice! I did not know that Chevy made a Murphy pillow that year...must have been a special order item. steve | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | Thanks Steve, Murphy thinks she is a human. I am starting to believe she is at least part human. She watches more tv than anyone in the house. Her favorite channel, animal channel of course. | | | | | Joined: Jan 2007 Posts: 7 Junior Member | | Junior Member Joined: Jan 2007 Posts: 7 | coach-frank what is the seat from .thanks tom [email protected] | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | Chevy s10, I have no idea what year. We had it recovered by a friend of mine. | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Sounds like Gazim did okay with spray contact cement. I use High-Temp Adhesive Spray for anything in the interior ... anything else will not hold. Coach-Frank -- What did you use to glue the faux-suede to your headliner with?
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | Camie 397 adhesive. A professional auto interior shop adhesive. | | | | | Joined: Jun 2006 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 85 | i use 3M Hi tak 76 on all my headliners it doesn't break down in the heat. DS | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Wish I could remember what I used. All I know it was 3M spray I got at home depot. and it is going on its 2nd year. Maybe I will be looking for the hi temp stuff this summer?  | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | If you're going on your 2nd year and nothings coming down, then you must have used high-temp, gazim. Anything else would start coming apart in just a few days ... even in cold weather.
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Hi all, I hope I can jump in here to ask a question. I have a 1957 Chevy 3100. I am restoring the truck back to 100% stock. I have ordered 2 different headliners from 2 different companies Classic Parts of America and Truck Parts out of Orange County. I have yet to find an exact reproduction of the orginal. Is there anyone out there still make the exact same original? Or should I take it to an upholstery shop to see if they can duplicate? Thanks for your time. Jon 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I've never seen a real repro of the TF headliner, all plastic now - a good upholstry shop might come close but I doubt they'd be able to come up with the right jute backing, or the correct waffle pattern material
Bill | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | I sold my truck about 2 yrs ago, but here is a link that shows some pix of the headliner.. I bought the cardboard type from the Filling Station cover it seems like Paid him 50 bucks to do it.. click here for link to pix Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Hi all, Can I use the products mentioned above (3M Hi tak 76 or Performance-High-Temp) to use on my jute headliner? Thanks Jon
1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the 3M works fine for that Jon
Bill | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Hey Bill, What did Chevy use originally? Looks like some type of black tar ..
1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | yeah, it was some kind of tarry stuff like an undercoating, probably brushed on like roofing lap cement, seems to have gotten brittle with age - I'm using the rubberized rocker guard spray on the inside of the bus skin, helps stop condensation, but I think it sets up too fast to be useable as a glue for overhead
Bill | | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | Another vote for 3M Hi Tak 76. Holds up for years. | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Hankdogg, Thank you...Can you pick it up at Napa Auto? 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | Napa does have it locally, also any body and paint supply shop will have it as well.
Hank
| | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Jan 2007 Posts: 117 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 117 | any headleaners for sale ?? for a 47,two piece
care to chat write back
| | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Hi mickster, Did you post your ad in the parts wanted topic?
| | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Ordered the performance hi-temp trim adhesive spray from "Your Auto Trim Store" Cost 9 bucks to buy 13 bucks to ship UPS to California. 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | I just was looking at the ingredients of the Performance High Temp Trim Adhesive. It contains acetone. Now as far as i know acetone is a paint remover. The top of my cab is painted. Should I worry about this?
1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | I wouldn't worry - the acetone is likely part of the setting process, it evaporates rapidly, and if there would be a problem with using it on painted surfaces there'd be a warning on the can as it's intended for gluing things on vehicles - see here - and hey! how'dya get that shipped to California?  Bill | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Bill. You never miss a thing...I have no idea..Placed the order on line through their website no questions asked. Economic hard times? Thank you for the help.
Jon 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Nov 2008 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 101 | I made my own abs plastic head liner... What material did you use for this? Where did you get it? Do you have to have an old headliner to use as a pattern or is there some way to figure it out? | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Hi, The adhesive I bought is a great product! My friend and I sprayed it on to the original headliner jute and let it tack up in the 2 minutes the directions said to follow. We learned not to spray it on in direct sun. By the time we got it to the cab, it was dry. So, we then sprayed in the shade and went right to the cab roof. It is very fast in drying. If you do this, make sure you have a least 2 people and line up the headliner. Installing the rubber molding around the liner was the hardest part...lost of soap! IN Thank you all... Jon
