8 members (TUTS 59, MaxStewart, KEVINSKI, HandyAndy, Otto Skorzeny, Gray_Ghost, Steelonsteel, 1 invisible),
129
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,113 Posts1,056,584 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 110 | I have a crank out window in my 46. The problem is I think it's going to the last round up in the sky. Who do you recomend buying a unit from?
Does this unit have some kind of rubber friction device, because I notice no cogs or teeth on the bar that pushes out the window.
How hard is it to replace?
Dan Mascheck Wharton, TX | | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | Hi Dan, I would recommend Ebay. They have originals occationally, including one currently I believe. It doesn't use rubber. It does have a cog with very widely spaced teeth. The stainless "arm" that pushes the window out, curved so it will hold it's shape, but somewhat flexible also, has widely spaced wholes that accept the teeth. It is pretty easy to install excepting rusty screws. Just get a whole unit, including the pusher "arm". Then just bolt under the dash, and attach the arm to the windshield with two screws...easy. Make sure any auction advertises good teeth and drive units. I'm sure they can be found new from the truck guys, I think, but some good originals still out there from my Ebay hours  | | | | | Joined: Nov 2006 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 110 | Ok, Ebay is fine, but what do you call it to do the search for the item? | | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | When I'm hunting I always start with 194*(the astrisk will get anything in that spot) so essentially that gets you all of the fortys. Add to that: windshield crank. Get creative and you may find one with another search. just depends how the person listed it also. What I have given above will produce one currently. BTW, they seem to be bringing between 60 and 80 for a pretty nice complete unit (or as I remember), so let that weigh in as you consider a bid. One last thought, I think 41-47 early will work, all the same. Good luck. | | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | Upon visiting this auction, it looks a little dead also. keep watching. I always seem to see one listed as I'm looking thru parts. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I have had good service from " bowtiebits ", or perhaps Jum Carter Truck Parts. I think the piece is called a " windshield regulator ", or crank assembly ? | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I have had good service from " bowtiebits ", or perhaps Jim Carter Truck Parts. I think the piece is called a " windshield regulator ", or crank assembly ? | | | | | Joined: Nov 2006 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 110 | Thanks for the help. I will keep looking on Ebay, but will look at the site you told me about!!
I assume they are all reconditioned? There are no new ones?
Dan | | | | | Joined: Dec 2005 Posts: 200 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 200 | New ones are at the truck part sites in the links here at TSP. | | | | | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | Dan, most of the ones offered are repaired units, I don't know of anyone who sells a replacement Regulator. Your unit MUST be rebuildable to get a new one. I will look and see if I can find the info on a source. Again they do come up every now and then on Ebay but they are on the Big Buck side. Most of the time the pot metal drive gear for the windshield strip is worn smooth. Would be nice if some one would make a replacement gear for them.
"If it ain't Steel it ain't Real" "Earth the insane aslyum for the rest of the Universe" 41 1/2-ton, a work in progress 68 Shortbed stepside 327/325hp/700R4
| | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | There's another just poped up on EBay | | | | | Joined: Nov 2006 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 110 | I don't have a problem if it can be fixed. When you screw it down it will hold shut, but now it will not open the window. I can push the window out and it seems to hold unless you have a big gust of wind or a gravel truck goes by.
I notice holes in the extension rod, but they are sure far apart. Hard for me to see how a cog with teeth or spikes can fit the holes so far apart! I wish I could see an exploeded version of it somewhere.
What happens if yours can't be repaired?
Thanks! | | | | | Joined: Nov 2006 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 110 | You say in the links page. There are many links and I have looked at many. All I have found was the rebuilt ones. Can you narrow it down for me please?
Dan | | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | Dan, I think it's time to pull yours out to get the best possible exploded view. Maybe yours can be fixed at that point, or it will be out for a replacement. You will also be able to see how the cog/holes work with it out. | | | | | Joined: Nov 2006 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 110 | I would like to pull it our to look at it, but it is a tight squeeze and I don't know how it's attached! I keep wishing I could see an explosed view, so I knew what I'm doing? I don't want to screw something up. I also have the truck in teh shop having the rear end recentered! A long story!
I have AC in the truck, so again it's a bit tight! I would like to fix the crank! It's nice to have the windshield open on a nice cool fall day with a slight breeze blowing through the truck!
Dan | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Dan, give these guys a call, just found a few old items from them. Ask for BILL! They run a full page ad in VCCA's NL. **** Moffitt's Chevy Parts Springfield, OH Ph. 937 325-7861
Good luck Jim | | | | | Joined: Nov 2006 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 110 | Jim,
I will call them tomorrow. Do you know if they have a website?
Dan | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Dan, I don't believe they have a web site or email, sounds like they are way to busy to fool with any of that high tech stuff. Appears they have a wherehouse full of stuff, sounded on the phone, they were climbing ladders etc scurrying around finding my OLD stuff. Nice guys. | | | | | Joined: Nov 2006 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 110 | Jim I'll give the a call tomorrow. I wish they were closer, but service is everything to me!
Dan | | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | Hey Dan, tight squeeze yes, but easy with the exception of some pretty tightly rusted bolts. You don't have to dissassemble it in the truck, just take loose the bolts (2) that attach the bracket to the windshield, and the crank to dash bolts. Should fall right out (oh and handle but that goes without saying)  | | | | | Joined: Nov 2006 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 110 | Thanks for the help. I'll give it a try when I get the truck back!
Dan | | | | | Joined: Jul 2004 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2004 Posts: 85 | Dan, If you don't have any luck, give Tom Myers Truck Parts in Miami Ok a call. I've bought a lot of parts for my 46 (sold)from him. Good parts and good price. He has lots of trucks. Phone 918-542-3871 Tell him Ed in New Orleans said hello. http://rides.webshots.com/album/352489004WcrToY | | | | | Joined: Nov 2006 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 110 | I'll give him a call today! Nice truck!
Thanks Dan | | |
