6 members (Otto Skorzeny, Southerntruck, Uncles51, wilbur53, Hotrod Lincoln, ronsway), 79 guests, and 1 robot.
Topics128,077
Posts1,056,280
Members48,441
#165101 12/15/2006 9:28 PM
Ive been going over the manual looking for help but have not found much. I amd removing all cab and door parts for painting and am haveing trouble with the gauge cluster. Has any one done this before?
thanks in advance.
#165102 12/15/2006 9:56 PM
everyone has done it numerous times!!
there's 3 philips screws in the bezel face, remove those and the speedo cable and you can usually wrestle the complete cluster forward enuff to disconnect the wiring, tho you might find it easier to get under and disconnect everything first ... it just pulls out thru the front .... with difficulty, keep tryin!!! grin
#165103 12/15/2006 11:31 PM
dont forget to disconnect the battery first!!!
Moderated by  ndkid275, Phak1
