7 members (2-Ton, WICruiser, Southerntruck, TUTS 59, Bill Hanlon, Ponchogl, DaveV),
98
Mod | | | Forums66 Topics128,129 Posts1,056,362 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 111 | Ive been going over the manual looking for help but have not found much. I amd removing all cab and door parts for painting and am haveing trouble with the gauge cluster. Has any one done this before?
thanks in advance. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | everyone has done it numerous times!! there's 3 philips screws in the bezel face, remove those and the speedo cable and you can usually wrestle the complete cluster forward enuff to disconnect the wiring, tho you might find it easier to get under and disconnect everything first ... it just pulls out thru the front .... with difficulty, keep tryin!!! Bill | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | dont forget to disconnect the battery first!!! | | |
