1 members (qside), 72 guests, and 2 robots.
Topics128,049
Posts1,055,741
#164797 10/06/2006 11:42 PM
I have a '50 3100 and have a deluxe fresh air heater. My heater has the cable setup for the defrost. I know other years just have an arm to switch to defrost. Does anyone know which years had the cable and which years had the arms? Thanks in advance.
1950 Chevrolet 3100 Deluxe Cab
Gallery Page
Webshots photos
#164798 10/07/2006 1:39 AM
On a 1954 Deluxe Heater (Air Flow Heater, vs the standard Recirculating Heater), the cable opens a door on the front of the heater. The defrost door-deflector is opened and closed with an arm.
You cannot see the cable in the upper heater in this 1954 picture but you can see the defroster arm.
#164799 10/12/2006 11:49 PM
Thanks, this shows me that I do not have a '54 heater. I do not have the door out front. Mine is a Deluxe, but rather than the arm to move the defrost door, it is set up for a cable to move it, ie clamp for cable sheaf and arm has hole for cable. Still trying to figure out what year this was.
1950 Chevy 3100
261, 4 speed
Purchased 1977
1964 Pontiac Lemans Convert
#164800 10/13/2006 11:10 PM
That heater was probably used on all of the AD trucks, I know it was also used on the 54. There were three types of heaters... recirculating, fresh air (the one you have)and the deluxe which was mostly on 54s and some 53s had it. The 53 and 54 could have had any of the three. Your truck could have had the recirculating or the fresh air.
#164801 10/21/2006 12:54 PM
Is there anywhere that the different heater options are pictured/described for the 1950 year? I haven’t found them in the Shop, Assembly or Accessory manuals? The Accessory Price list shows two options for a truck, Heater & Defroster –Air Flow and Heater & Defroster – Dash, what was the difference between the two?
My truck has two hoses coming off the heater and going to the defroster outlets, does that mean that I have a Heater & Defroster Dash?
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
#164802 10/21/2006 3:11 PM
Denny,
There were only two GM accessory Heater/Defroster units in 1950 (late 1949-1950). The "Outside-Air Ventilator, Heater and Defroster" (this does not have the cable-controlled door on the front face - the cable controls the defroster in 1950); and, the "Dash Reciculating Heater and Defroster Unit" - this is the more common, less expensive unit that has no cable-control and has a deflector-lever on the body of the unit, for the defroster).
I will post scans in a few hours of the original 1950 heater/defrosters and original price list.
Most likely you will still not be able to see things at my website (same problem as in other thread). Try the link below and please send me your IP address (ignore the rest of that page).
I am very sorry about the pop-ups from the other link - I have my web browsers set to block all pop-ups, so I have no idea of which sites use those obnoxious features. The link below will have no pop-ups (but, ignore the stuff at the bottom of the page).
Please send me the IP address.
Tim
lederman@siena.edu
#164803 10/21/2006 5:06 PM
Here is a web directory of images from an original late-1949/1950 Chevrolet Truck Data Book. There are two images with heater information:
Picture of 1950 Accessory Heaters
1950 Accessory Price List - includes both heaters
#164804 10/22/2006 1:24 PM
Ya know TC, I would love to send you my IP address if I could find it. this is the second day I have looked for it on this new confuser with XP and I just can't find it any where!
Denny G
Denny G
Sandwich, IL
#164805 10/22/2006 2:09 PM
Denny,
Sorry about the problem. Did you try to go to this link to see your "Client IP" address?
http://66.194.176.101/~ks5217/
Were you able to see the links at this web directory?
http://72.228.53.69/Web%20images/
Tim
#164806 10/22/2006 3:11 PM
Can’t open, http://66.194.176.101/~ks5217/
HEY, HEY! Can open, http://72.228.53.69/Web%20images/
Is that out of the “Salesman’s, Truck Data Book”? I have one of those coming, but I will download the images and add them to my folder.
Looks like I have the Outside-Air Ventilator, Heater and Defroster, god I hope the core is alright in it, I’ll bet they are hard to find.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
#164807 11/14/2006 12:09 AM
Junior Member
Junior Member
Looking for a source for 57 chevy 3100 series pick up - heater core for standard heater. I have the old one, but no local radiator shops will touch it. I am in Ft. Lauderdale but will be happy to have a source anywhere. Thanks,
Bob K
Bob K
[email protected]
954 536 7515
Moderated by  ndkid275, Phak1
