1 members (Hotrod Lincoln),
41
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | I had thought that I have all of the interior metal panels for my ’41 Master, but now that I have begun to clean up behind the seat I’m not sure. I have the nicely shaped upper rear panel that also frames the back window and the two lower corner panels that extend from up by the cab beltline to the floor and from the doors about a foot around the back side. I had assumed that there was no center panels as the area is hidden by the seat, but now I have found a row of small holes in the center stiffener (behind the seat) so I’m thinking there could have been a interior panel there. Anyone got any idea?? If there was one was it metal or fiberboard?? | | | | | Joined: Jul 2006 Posts: 232 New Guy | | New Guy Joined: Jul 2006 Posts: 232 | My 39 is the same. Mine also has holes in the center brace. Ive never seen a replacement for sale so I just plan to get some type of panel and cover it to match the rest of the interior. | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Kip, I don't think there ever was any kind of pannel there. If you want one (which I think is a good idea) it's easy to build one out of fiberboard as you suggested. Make sure you tuck some sound deadening and insulation in behind it. Good luck George | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | My 4t6 has same holes and I figured I would cover with a door skin covered with some upholstery material. Mine is almost ready for paint and hope to start putting back together this winter if all goes well. Haven't posted to much lately with work and home computer woes.
Dan | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Thanks guys.
I think mine will have to settle for fiber board and some insulation as I do not have an extra door skin. Looked closely,with a magnifying glass last night (getting old and eyesight aint what it used to be) and could not see any threads in those holes. So maybe they are just there to let the water (from washing out the cab) out. | | | | | Joined: Jul 2004 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2004 Posts: 85 | Kip, my 46 was the same as yours. After insulating the cab I covered with fiberboard. Good luck http://community.webshots.com/user/46metal | | |
