3 members (TUTS 59, Forty9, Robert Crandall), 75 guests, and 3 robots.
Topics128,213
Posts1,057,488
Members48,473
im collecting all of the green tinted glass round glass, rear windshield door, ect. for my 51, whats the best way to store it if it wasnt going to be used for several months? lay flat ? stand up somehow????
doesn't matter at all - lay it flat so you can step on it, or stand it up so you can kick it grin
"best" is in a corner outta the way and if you have similar pieces together put some newspaper between so grit can't scratch it if it's jostled
I've seen them taped between two pieces of cardboard and stood upright in a safe location, You should probably store them in another location from your work area so they don't get broken. This way by the time you are ready to use them you forgot where you put them. smile
Ed
Put them in the overhead storage in your garage, safest place to keep them away from possible licks, bumps, etc.
Bill Burmeister
I stored mine between cardboard under my bed.
47.5 Loadmaster 5 window
48 Chevy 3600
69 GTO convertible
Standing up is best. on wood or something to cusion the edge from chipping. wrapped with heavy paper with news print between the panes is good. Standing is advised as it is safer for the glass to pick it up and handle in a vertical position. the edges need to be protected from chips, ect, repeat, the edges need to be protected. But glass is stronger than you would believe.
"It ain't a truck if you can't hose out the cab."
I have mine wrapped in bubble wrap, standing up in my closet and a word of warning to the wife if broken to pack her stuff and leave fast or push up daisy's in the back yard. lol
Quote
So I guess your truck is not driven a lot.
i usually toss my glass up into the attic...
I did have a passenger side door glass for a 77 Honda Accord, dragged it around for about 10 years and it never got broken... even stored under my bench... eventually threw it into the trash, unbroken.
Another quality post.
Real Trucks Rattle
I have the typical pull up doors and I hang anything I don't want damaged from the ceiling there. I have a hood hanging there for over 5 years now. That space does't seem good for anything else anyway.
I think they make a storage system for that space I have my hood hanging on nylon tie down straps.
1937 Chevy 1/2-Ton
I wrapped mine and put behind storage cabnet .
Moderated by  ndkid275, Phak1
