0 members (),
137
Mod | | | Forums66 Topics128,211 Posts1,057,475 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 243 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 243 | im collecting all of the green tinted glass round glass, rear windshield door, ect. for my 51, whats the best way to store it if it wasnt going to be used for several months? lay flat ? stand up somehow???? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | doesn't matter at all - lay it flat so you can step on it, or stand it up so you can kick it "best" is in a corner outta the way and if you have similar pieces together put some newspaper between so grit can't scratch it if it's jostled Bill | | | | | Joined: Jul 2005 Posts: 308 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 308 | I've seen them taped between two pieces of cardboard and stood upright in a safe location, You should probably store them in another location from your work area so they don't get broken. This way by the time you are ready to use them you forgot where you put them. Ed | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Put them in the overhead storage in your garage, safest place to keep them away from possible licks, bumps, etc.
Bill Burmeister | | | | | Joined: Dec 2002 Posts: 86 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2002 Posts: 86 | I stored mine between cardboard under my bed.
47.5 Loadmaster 5 window 48 Chevy 3600 69 GTO convertible | | | | | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | Standing up is best. on wood or something to cusion the edge from chipping. wrapped with heavy paper with news print between the panes is good. Standing is advised as it is safer for the glass to pick it up and handle in a vertical position. the edges need to be protected from chips, ect, repeat, the edges need to be protected. But glass is stronger than you would believe.
"It ain't a truck if you can't hose out the cab."
| | | | | Joined: Oct 2005 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2005 Posts: 40 | I have mine wrapped in bubble wrap, standing up in my closet and a word of warning to the wife if broken to pack her stuff and leave fast or push up daisy's in the back yard. lol | | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | Originally posted by Ray S: I stored mine between cardboard under my bed. So I guess your truck is not driven a lot. | | | | | Joined: Dec 2002 Posts: 3,445 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,445 | i usually toss my glass up into the attic...
I did have a passenger side door glass for a 77 Honda Accord, dragged it around for about 10 years and it never got broken... even stored under my bench... eventually threw it into the trash, unbroken.
| | | | | Joined: Jul 2006 Posts: 190 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2006 Posts: 190 | I have the typical pull up doors and I hang anything I don't want damaged from the ceiling there. I have a hood hanging there for over 5 years now. That space does't seem good for anything else anyway. I think they make a storage system for that space I have my hood hanging on nylon tie down straps. | | | | | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | I wrapped mine and put behind storage cabnet . | | |
