2 members (LAROKE, baldeagle),
63
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 31 Member | | Member Joined: Oct 2005 Posts: 31 | Just received steering column bushing for my 1938 HC p/u from a reputable vendor. It is going to be a very tight fit! Also, is this bushing installed from the top or from the bottom of the steering column?? I see there is a tab projecting from the inside wall of the steering column. Does the bushing sit on top of or underneath that tab? Tnx. | | | | | Joined: Feb 2000 Posts: 5,195 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,195 | The bushing goes in from the top with the brass horn ring facing up. On the 1/2 tons the column has a smaller diameter place where the bushing fits tight in to. The small tab you see is what keeps it from going all the way through. If you don't mind me asking, which vender did you get that from? They all quit selling them for awhile and I had to make mine from hardwood. I soaked it in oil for a week and its still working OK, just a little loose. Joe | | |
