4 members (Stovebolt48, Steelonsteel, Bill Hanlon, lumbersawyer), 31 guests, and 2 robots.
Topics128,037
Posts1,055,466
Members48,422
#164560 07/26/2006 6:40 PM
Just received steering column bushing for my 1938 HC p/u from a reputable vendor. It is going to be a very tight fit! Also, is this bushing installed from the top or from the bottom of the steering column?? I see there is a tab projecting from the inside wall of the steering column. Does the bushing sit on top of or underneath that tab? Tnx.
"You are only young once, but you can ALWAYS be immature!"
1938 Chevrolet H/C 1/2-Ton
#164561 07/28/2006 5:25 AM
lobo49,
Have you been to this site? Sometimes the pictures can help you stick things back together.
http://chevy.tocmp.com/1929_54chevyparts/06/396.HTM
Stuart
#164562 07/30/2006 5:01 PM
The bushing goes in from the top with the brass horn ring facing up. On the 1/2 tons the column has a smaller diameter place where the bushing fits tight in to. The small tab you see is what keeps it from going all the way through. If you don't mind me asking, which vender did you get that from? They all quit selling them for awhile and I had to make mine from hardwood. I soaked it in oil for a week and its still working OK, just a little loose. Joe
Moderated by  ndkid275, Phak1
