0 members (), 231 guests, and 1 robot.
Topics128,089
Posts1,056,141
Members48,436
#164460 06/26/2006 8:22 PM
Does anybody know how to remove the entire bench seat frame in a '49 3100, without destroying it in the process? I saw the online manual on adjustments, seat removal, etc., but 0 on the frame removal itself. Need to get it out to repair floor and in-cab fuel tank. Thanks!
#164461 06/26/2006 9:37 PM
It's fairly easy. The first step is to get the seat back out of the way, there are three screws along the frame at the top.
Next take out the bottom of the seat.
Next there are a couple of bolts in each of the front corners of the seatframe/adjustment tracks that hold them to the 'riser' which is welded to the floor of the cab.
Finally there are a copule of bolts in the on either rear corners of the seat base.
Once you get the back and bottom cushion out of the way you can probably figure it out yourself by just looking at it.
I suggest wearing gloves and a mask, and having a shop vac ready when you get the seats and tank out, there are stories about what you'll probably find there! I found the original key to the ignition with the knock out still in place. Guess the owner dropped it behind the seat and it fell behind the tank! Most likely you'll find mouse droppings, dust, dirt, bugs...
#164462 06/26/2006 9:59 PM
Thanks, I'll be able to get at the frame sooner than I thought, but it's the "riser" that I really need to remove. Just split the welds and repair any holes created?
#164463 06/26/2006 10:36 PM
Basically, the "riser" provides significant structural stability to the cab. If you do need to remove it, you will need to weld in some temporary additional supports for the cab or you might experience "oil canning".
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin
"Always do right. This will gratify some people and astonish the rest." - Mark Twain
#164464 06/27/2006 4:46 AM
Thanks Jeff, something told me this was a significant removal, I appreciate your cautionary reply. Tomo
#164465 06/27/2006 4:43 PM
Several of the vendors offer 'streetrod' floor plans to replace where the riser is and make the whole thing flat rather than with the stock dip under the seat. Those kits might include support for the floor and cab since losing the riser reduces the amount of lateral reinforcement in the cab.
#164466 06/27/2006 8:28 PM
Also you will have to unclamp the seatframe from the seat adjustment cables. There's a clamp that bolts to the cable in the middle of each side. The fore and aft seat adjuster in 49s only latches on the driver side. Both sides clamp to a cable that keeps them parallel running back and forth. If you decide to replace the cable (apparently you can get one with clamping at Home Depot), be sure it crosses along the back so that the outside cables left and right move in the same direction.
Never start vast projects with half vast ideas.
Moderated by  ndkid275, Phak1
