0 members (),
110
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,196 Posts1,057,394 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 56 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 56 | Has anyone made or fabricated or found any original-looking knobs for an electric windshield washer switch (New Port Engineering electric windshield wiper conversion) for a '53 Chevy dash????? I'd sure like to make a knob that looks like the choke knob or the light switch knob, but it seems like a lot of work, or else an expensive job at a machine shop. | | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | You can buy the knobs from Jim carter and others and then fit them on with epoxy, a set screw or some other manner.
Personally, I'm using a replacement chrome wiper nob that I've drilled a little hole in and installed a set screw to hold the knob in place on the New Port Engineering switch.
I'm hoping to do something similar with the a/c control switches using light switch replacement knobs.
